911 rear hub compatibility, Simple 5 lugger 911 cross over comparison |
pnewman |
Mar 22 2013, 08:09 PM
Member Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
Simple 5 lugger comparison question of compatibility pro's and con's.
I have 4 lug drilled hubs and I am contemplating using 911 hubs on a new set of rear swing arms. I did a couple of searches on the "Search" tool and it provided no fruit. I am still hungry. (IMG:style_emoticons/default/idea.gif) Which 911 hub(s) are compatible with out 914's? Which are best? Which are direct fit? Which need mod's? Thanks for your advise! (IMG:style_emoticons/default/popcorn[1].gif) |
SirAndy |
Mar 22 2013, 08:13 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I did a couple of searches on the "Search" tool and it provided no fruit. You need to try harder ... (IMG:style_emoticons/default/poke.gif) http://www.914world.com/bbs2/index.php?showtopic=105728 (IMG:style_emoticons/default/beerchug.gif) |
Harpo |
Mar 22 2013, 08:16 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I went with option #4 and I'm very happy with the results although not cheap by any means. I purchased an my old 911 axles and input and out flanges off the pellican forum.
David |
pnewman |
Mar 22 2013, 08:17 PM
I did a couple of searches on the "Search" tool and it provided no fruit. You need to try harder ... (IMG:style_emoticons/default/poke.gif) http://www.914world.com/bbs2/index.php?showtopic=105728 (IMG:style_emoticons/default/beerchug.gif) Fed, Thank you. (IMG:style_emoticons/default/beerchug.gif) Now if I can only figure out why my search failed. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 27th December 2024 - 03:49 AM |
