suspension question |
dawg |
Mar 23 2013, 09:19 AM
Newbie Group: Members Posts: 16 Joined: 23-March 13 From: New Jersey Member No.: 15,685 Region Association: None |
newbie here
not looking for judgement or opinions, just simple question about koni front strut housings and what inserts fit koni obviously, but what about kyb g series blistein other? |
bulitt |
Mar 23 2013, 09:51 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
brant |
Mar 23 2013, 09:59 AM
914 Wizard Group: Members Posts: 11,824 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
kyb's have cruddy valving for this weight of a car
they are often referred to as "kill yer back" I'd avoid them on a 914 bilstein and koni's have the reputation of being the best stock valving, performance shocks on these cars there are racing shocks too... but a different question than your asking. |
Mblizzard |
Mar 23 2013, 07:33 PM
Eric gave some good guidance in http://www.914world.com/bbs2/index.php?sho...261&hl=Boge
jmill |
Mar 23 2013, 08:09 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Are you talking stock 914 struts or 911 struts which I believe came in Koni, Bilstein and Boge.
Attached image(s) |
dawg |
Mar 24 2013, 07:40 AM
Eric_Shea |
Mar 24 2013, 08:03 AM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
If they are truly 911 Koni struts then only Koni inserts will fit.
dawg |
Mar 24 2013, 08:14 AM
If they are truly 911 Koni struts then only Koni inserts will fit. why do the suppliers offer other inserts for 911's (years 78-83) which I thought were all koni strutted cars I measured kyb inserts and they are identical in measurements to koni inserts - only exception is the kyb's have a "nub" on the bottom of the insert - fit seems ok |
brant |
Mar 24 2013, 08:46 AM
I didn't think the SC series had koni struts....
maybe koni inserts but not struts the SC's and Carrera's did have 3.5 spacing but I thought they all came with Boge or something struts I though the actual koni struts were roughly from about 1970- to 1976-ish years and only an option on those years (S caliper option) versus the standard strut with 3inch spacing John's pictures show the difference well you can see how the housing becomes larger on the koni just above the mounting point for the spindle... on the others it is the same tube size. this is why you don't see koni struts with spindle mounting location modifications (the taper) I run koni struts which are sectioned for a drop but then race shocks inside to accomodate the modification and give travel to a lowered car. check the shape of the struts on your car |
Eric_Shea |
Mar 24 2013, 10:40 AM
It's all about the thread pattern on the inserts.
Most 911SC models (the years you specified) came with "Boge" struts. Those later SC Boge struts (black as per the pictures above) have the 3.5" spacing "but" they have a "Boge" thread pattern for the insert. Koni makes the orange struts you see above. They have a Koni thread pattern so only Koni inserts fit these struts. Same thing with the green Bilsteins you see above. Bilstein thread pattern and Bilstein inserts. Because Boge was so prevalent in the SC's (almost all of them), the other manufacturers make replacement inserts for them with the Boge thread pattern so, in a way, they're more desirable for the multitude of insert choices (even if some of those choices are KYB) (IMG:style_emoticons/default/wink.gif) |
dawg |
Mar 24 2013, 03:23 PM
OK, it is out of an older 911... (74-77)
Part number 91134107916 I think this will take other than "koni" inserts?? |
Eric_Shea |
Mar 24 2013, 03:45 PM
http://www.porsche.com/all/media/pdf/origi..._77_KATALOG.pdf
I'm not seeing it: 079 36 = Bilstein 079 00 = Boge What color is it? Are they orange? I'm finding it in Google searches but not on the factory PET. It should have a manufacturer stamped on it. It appears they "are" Koni from various listings. That would mean Koni inserts. |
brant |
Mar 24 2013, 05:20 PM
OK, it is out of an older 911... (74-77) Part number 91134107916 I think this will take other than "koni" inserts?? measure the bolt spacing where the calipers bolt on, and also the see if you can determine the original color another indicator is to look at the top nut that holds the insert in (its the nut that the shock goes through the middle of) I believe the fine thread nuts are koni, and the course thread are something else. see if you can determine what the original color would have been under any of the grime. |
SKL1 |
Mar 24 2013, 07:40 PM
Senior Member Group: Members Posts: 1,646 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Just got Koni sport inserts for my '73 I'm restoring. Paragon has them on sale 20% off.
I'm using '71 T front suspension with Boge struts so you just order the appropriate inserts for what suspension you have. Rears are all the same for any 914. |
dawg |
Mar 24 2013, 07:46 PM
Made by Koni is stamped on them. Hard to determine the original color.
All that said, If I can fit another insert in and have the matching cap to hold it into the strut, am I good to go? |
Eric_Shea |
Mar 24 2013, 07:51 PM
Do you want to sell them? I have something your KYB's would fit into.
brant |
Mar 24 2013, 08:04 PM
you are going to have to use koni inserts...
if they are wedge pin style I'm looking for a set also so apparently two interested parties, and you might be able to sell them if you don't want to keep them. |
dawg |
Mar 24 2013, 09:09 PM
Going to keep the struts, thanks for the interests though.
I guess my question isn't fully understood. I have a set of koni inserts (used), I have a set of KYB inserts new. The KBY inserts fit fine in the Koni struts. They sit in the tube, the KYB top strut nut fits fine. The length of both inserts (KYB and KONI) when the pistons are fully extended are the same. I'm not understanding why it seems most of you are saying I have to use Koni inserts. I must be missing the point or not understanding something. It just isn't regestering in my head. |
brant |
Mar 24 2013, 10:20 PM
maybe they would work since everything measures the same
I've never heard of it though it was a well known fact that nobody but koni made koni strut inserts maybe that has changed though... however the kyb are well known to be pretty terrible and overly harsh If they fit you can stick them in and give them a try... if they are too hard for your taste then you can buy the koni inserts. |
dawg |
Mar 25 2013, 11:26 AM
maybe they would work since everything measures the same I've never heard of it though it was a well known fact that nobody but koni made koni strut inserts maybe that has changed though... however the kyb are well known to be pretty terrible and overly harsh If they fit you can stick them in and give them a try... if they are too hard for your taste then you can buy the koni inserts. Finally got it all sorted out and will be putting koni inserts in. Thanks! |
Lo-Fi Version | Time is now: 26th December 2024 - 11:31 PM |
