Is there an easy way?, Replacing rubber brake lines |
Carlitos Way |
Nov 20 2004, 01:34 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
Hi,
I'm wondering if there's an "easy" way to remove the rubber brake lines. I can get the lower part out, no problem... but is there a trick to removing the top part? hard to get in there and break it loose. thanks, Carlos |
campbellcj |
Nov 20 2004, 02:26 PM
I can't Re Member Group: Members Posts: 4,557 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Be sure you use flare nut wrenches (designed for brake lines) as anything else is much more likely to round off the nuts, and then you're hosed!
davep |
Nov 20 2004, 04:13 PM
914 Historian Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
There is no easy way. I often use my plumbers torch to heat the joint. You have to be very careful doing that. First, drain the line, you don't want fluid in it if you use a torch. Apply a little heat, and try the flare wrench. The plumbers torch is acetylene without the oxygen, and makes a very small hot flame; small controlled flame is the reason I use it, and why I don't use a propane torch. An assistant with fire control equipment on hand is a must when I try this. |
BPGREER |
Nov 20 2004, 10:51 PM
Member Group: Members Posts: 131 Joined: 29-September 04 From: SAN FRANCISCO Member No.: 2,857 |
If I remember right, you can remove the drain plugs from the engine bay, which gives you a small access to the top. At least that way you can see what's going on up there. And seriously use the flare nut wrenches, their definatley worth it.
Brian |
JoeSharpOld |
Nov 20 2004, 11:01 PM
Does it seem cold to you Group: Members Posts: 361 Joined: 29-April 04 From: Camping in Neverland Member No.: 2,001 |
The best way I found to do the rear was to remove the motor. But then sence you've got the motor out why not do the??? And it will be on jack stands forever. (IMG:style_emoticons/default/biggrin.gif)
Joe |
Aaron Cox |
Nov 20 2004, 11:05 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
i broke the hardline trying to get mine out! it is a PITA... it can be done...use the magic wrenches!
DJsRepS |
Nov 21 2004, 06:46 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
Buy some PB blaster, best penetrant you can get. If your still driving the thing don't soak it with this till your doing the work as it might eat the rubber hose and blow an line. The open end tubing wrench on the line is the best, don't try without. But if the line part is already rounded I have a pic of two tools a little hard to find qualaty tools this small. Iv taken alot of messed up lines out with these. Torch Heat? last ditch effort I would think. PB blaster 2wice a day for 2day just what the doc ordered. Also always have 2 tools on the fitting. Mainly solid hold on the line nut so you dont twist the steel line. With a solid hold on the steel line nut (and if no room to turn it or break it loose) try breaking it loose turning the steel part of the rubber hose from the wheel well side by the tire. The mini pipe wrench does alot better job and easyer to use than the mini vicegrips. For those familuar with plumbing those are genuine Ridgid heavy duty and qualaty ViceGrip mini grip
Attached image(s) |
Carlitos Way |
Nov 21 2004, 10:09 AM
Thanks guys. I think I might be ready to tackle the task armed with the knowledge you've shared.
IronHillRestorations |
Nov 21 2004, 02:58 PM
I. I. R. C. Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Only use vicegrips or pipe wrenches as a last resort. These will damage the hex fittings on the hard brake line, making use of a "real" wrench difficult if not impossible.
DJ is right about the penetrating oil. I've used the PB Blaster stuff for a couple years not, and it really works great. The best way to get to the upper fittings on the rear rubber lines is with a flare crowfoot, through the water drain hole in the engine shelf. This is a trick I got from Brad Mayeur. |
Carlitos Way |
Nov 21 2004, 06:06 PM
I tried everything... and no luck. I can't even see the top nut from the drain tube hole. Maybe with more light I can tackle this another day.... or I might have to just take it to a shop and have them do it.
Thanks for your suggestions, guys. Carlos |
DJsRepS |
Nov 22 2004, 04:08 AM
Hey if you read my message I did say the tubing wrench was the BEST tool and dont try without!!! (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 27th June 2024 - 06:36 PM |
