442nd914s |
Member ![]() ![]() Group: Members Posts: 139 Joined: 25-July 12 From: KC Suburb Member No.: 14,718 Region Association: None ![]() |
Found this loose wire underneath the dash. Travels under stearing colum and dissapears by the front trunk release. I havent checked for voltage but it looks like it would. 16-18 gauge wire with stock spade connectors Its on a '73
P.s. Its not the wire that goes to the speaker. That one is already accounted for Thanks in advance ![]() ![]() |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
NOT stock wiring.
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
It looks like a speaker wire. Does not look factory.
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Jmedeiros |
Member ![]() ![]() Group: Members Posts: 99 Joined: 12-November 12 From: Los Banos, CA Member No.: 15,138 Region Association: Northern California ![]() |
I just found one in the new project that went to a light switch for the rear trunk. Is there a light that's not working when you open the front trunk??
914Sixer |
NO front trunk light on 914's. Rear trunk light works only when lights are on and is part of the wiring harness.
Lo-Fi Version | Time is now: 25th June 2024 - 11:26 PM |
