> Rotor Thickness
76-914
post Apr 6 2013, 08:51 AM
I mic'd a new (from PP/not OEM) rear rotor last nite and found they are a tad bit shy of the OEM. Haynes lists the OEM at .374" which I verified off the old rotor's outer rim. You know the part that never gets turned unless you specify that you want it turned, also. (IMG:style_emoticons/default/shades.gif) However, the new one mic'd .365". Hmmmm. Does anyone remember the min amount that you can take off an undamaged rotor?
Mike Bellis
post Apr 7 2013, 12:18 AM
Resident Electrician
This is from the factory service manual...
post Apr 7 2013, 07:14 AM
Wow, thx Mike. Soon as the sun comes up I'm going to check that against Haynes. I'm keeping a copy of this. (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 28th December 2024 - 05:06 PM
