jesiv |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California ![]() |
I can't seem to find good jack stands at least the top. What do you consider the best jack stands for a 914?
Regards James |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Make sure there they have a pin in them. The ones with a lever are known to fail.
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,296 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
The best 914 jackstands are ones that can be removed from under a 914. There are some which once your 914 is put up on them they get stuck almost like welded under your 914. It's like you can't get them out from under there. Strange really...... (IMG:style_emoticons/default/sad.gif)
nathansnathan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None ![]() |
These are the best ones I have found. Since the bottom of the car is flat, they work well for for when both ends are off the ground. They are a little weird to use when you are lifting just 1 end though.
http://www.pelicanparts.com/catalog/shopca..._ESCOJS_pg2.htm |
r_towle |
The best 914 jackstands are ones that can be removed from under a 914. There are some which once your 914 is put up on them they get stuck almost like welded under your 914. It's like you can't get them out from under there. Strange really...... (IMG:style_emoticons/default/sad.gif) Its procrastination organic fusion. |
Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
The best free standing (triangle) ones have a circle welded on the top that just fits around the donuts on the bottom of our cars. Great for CA where we have big earthquakes. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Two post lift. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 25th June 2024 - 07:50 PM |
