John1180 |
Newbie ![]() Group: Members Posts: 36 Joined: 27-February 13 From: Seattle Member No.: 15,590 Region Association: None ![]() |
I tried search, but couldn't find anything. Any tips on this? Front bumper is off if that helps.
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
As I remember, there is a little hole somewhere around the latch. You can poke a screwdriver in there and release the latch. Push the mechanism to the right as you are facing it.
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
There is a small rubber grommet right in the center of the front header panel. Pop it out and it should allow you to manipulate the latch mechanism. (IMG:style_emoticons/default/agree.gif) ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Once you get it open, remove the cable from the housing to lube it and all the other moving parts.
John1180 |
Great tips, thanks!
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
check where the wire sleeve is captured at the latch. if it has slipped out of its clamp that can make for a real hard pull to release.
k |
Lo-Fi Version | Time is now: 25th June 2024 - 09:23 PM |
