lsintampa |
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States ![]() |
1975 914/4 2.0
Picture is of the LEFT side intake. Question 1 is do I have the correct fuel rail on the left side? Question 2 is what attaches to the middle of the fuel rail? There is a small threaded nipple right in the middle? I'm assuming some sort of bracket? Thanks, Len ![]() |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
You dont have to make a new thread to post a new picture, You should just "Add Reply" on the bottom right and you can add the pictures and such.
An admin will combine these posts at a later date. |
lsintampa |
You dont have to make a new thread to post a new picture, You should just "Add Reply" on the bottom right and you can add the pictures and such. An admin will combine these posts at a later date. I know... I wanted to keep them as seperate items. Thought it would be better that way to keep it simple. |
442nd914s |
Member ![]() ![]() Group: Members Posts: 139 Joined: 25-July 12 From: KC Suburb Member No.: 14,718 Region Association: None ![]() |
Answer 1: Yes
Answer 2: Nipple in the middle of the rail should have a screw. This port was designed to check fuel pressure. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
The nipple on the fuel rail is also used for fuel supply to the cold start valve
Lo-Fi Version | Time is now: 26th June 2024 - 02:30 PM |
