Dancingbull |
Newbie ![]() Group: Members Posts: 2 Joined: 20-April 13 From: Florida Member No.: 15,786 Region Association: South East States ![]() |
(IMG:style_emoticons/default/sad.gif) I have a 72 914 which was starting few weeks ago. When I went to started this week it would turn over but will not start. The fuel gauge said res.so I go two gallons of gas and put it in. Know when I try to start the gas leaks from the bottom of the car of the engine bay . Does this mean a sucked up some dirt from the tank and plugged up the carbs or a fuel line busted ?
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,302 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Check the fuel lines first and be careful of fire. If the lines are orginal I'm sure they are the problem.
Dancingbull |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
+1 on the fuel line. Don't do ANYTHING ELSE until you solve this problem. Do a search of "914 fire" and you'll see why.
Lo-Fi Version | Time is now: 26th June 2024 - 10:08 AM |
