Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
***Not for street use because there's no hand/emergency brake***
THAT SAID; this is part of our inventory reduction sale. We can currently make up about 3-4 sets of these rear 911 calipers without spacers (depending on how 911 rear sales are going and... they're going well so hurry). These would have the proper bias for a larger 911 48mm front piston. Here's what you would get: 15% larger pad (same as 911 or 914-6) 15% larger piston (same as 911 or 914-6) Bolt on upgrade for the rear to match the 48mm pistons in larger 911 front calipers w/o the spacers these calipers will bolt up to a stock 914 or 914-6 rear rotor (if you're five lug) "Perfect" bias match for the 48mm front pistons and not too large (E.G.: bolting an early 914 front on the rear). $99.00 per set plus shipping. ![]() |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 119,313 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
Eric, are these the ones we are talking about?
shuie |
Member ![]() ![]() Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 ![]() |
This is a really good deal. I bought a set a while back and just put them on my car this week. It's a nice upgrade for a system w/non vented rotors that won't require a lot of messing around bending new hard lines. The inlet on the caliper lines up perfectly with the new stainless rear hard lines that Eric also sells.
Eric_Shea |
Eric_Shea |
Down to 1-2 sets now.
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
It's not that hard to convert to a 911 emergency brake, than these calipers would also be great for the street too!!
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
I am in for 1 set
Eric_Shea |
These are sold out.
Lo-Fi Version | Time is now: 26th June 2024 - 02:58 AM |
