jmargush |
Member ![]() ![]() Group: Members Posts: 463 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
When using cylinder shims to achieve the proper deck height /compression ratio, do I leave in the thin original shim/aluminum gasket or does the new shim take the place of that?
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Kinda depends on how much height you need.
The Cap'n |
jmargush |
I really need .016 but the only shims I could get were .010 and .020.
So would it be ok to remove the standard shim and just run the .020? I guess what I am asking is can the thicker deck height shims replace the standard or do you still need to use the standard for sealing purposes? |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I really need .016 but the only shims I could get were .010 and .020. So would it be ok to remove the standard shim and just run the .020? I guess what I am asking is can the thicker deck height shims replace the standard or do you still need to use the standard for sealing purposes? You can use up to 3 shims, I'd run the .010 and the standard which IIRC is about .008. Only place I used to use RTV is under those shims, some use curil derko (basically same as RTV) or threebond. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:29 AM |
