KenH |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 ![]() |
Testing a 80% ZF Limited Slip
The Porsche repair books say hold the LSD body in a vice and see how much torque it takes to turn one axle stub. 914 book says 50 ft/lb. 911 book says 80 ft/lb. Also found a note that says put one axle stub in a vice and check the torque at the other stub, LSD body "floating". Should measure more than 25 and as high as 75 ft/lb. I measure 150 ft/lb. using the one stub method. and 40 ft/lb. if I check stub to stub. Comments? Thanks, Ken |
KenH |
Hummm - not even a "off the subjet" comment.
Sombody must have some LSD experiance. Ken |
Lo-Fi Version | Time is now: 25th June 2024 - 07:53 PM |
