My 2.4 Six Engine, Manufacturing prototype intake adapters. |
McMark |
Jul 15 2013, 07:30 PM
I picked up this 2.4 six awhile back and I'm gonna use this thread as I develop the engine which will eventually go in my gold car.
I'm starting a little out of order, but too bad. (IMG:style_emoticons/default/tongue.gif) So I have this aluminum flywheel. No manufacturer stamps or numbers on it whatsoever. I'm thinking that it might be too light for a street car, so I may not use it. It's about 3lbs by itself. I've got a 914 clutch adapter (basically a cut down 914/4 flywheel that bolts to the outer edge) and that brings the total flywheel weight to about 10lbs. I want a streetable car, is this thing too light? Attached image(s) |
ConeDodger |
Jul 15 2013, 07:37 PM
Apex killer! Group: Members Posts: 23,758 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Try it...
BKLA |
Jul 15 2013, 07:47 PM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
I have a lightened Patrick Motorsports flywheel on a 2.4 that I'm building. Its not aluminum and weighs 7.00 lbs. If yours is not less than 5 lbs, it should be fine, depending on cams. I'm using e cams based on Dempseys book. I am, by far, no expert tho. (IMG:style_emoticons/default/biggrin.gif) |
sixnotfour |
Jul 15 2013, 08:04 PM
914 Wizard Group: Members Posts: 10,525 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
your right at a stock 2.0 6 cylinder flywheel weight.. do you have an aluminum pressure plate the would be great, unless its for a LIMO, Then get a cast iron anchor..
brant |
Jul 15 2013, 10:46 PM
914 Wizard Group: Members Posts: 11,739 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
old and new flywheels
of course we don't have the torque of a 2.4 and we use an F first gear Attached image(s) |
sixnotfour |
Jul 15 2013, 10:48 PM
oh Brant that aluminum one is real vintage alright (IMG:style_emoticons/default/lol-2.gif)
brant |
Jul 15 2013, 10:49 PM
its Frank Becks toss off.....
he went to a 4.5 diameter clutch to save weight |
pcar916 |
Jul 16 2013, 03:48 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
I've had a 6.75lb Patrick Motorsports aluminum flywheel and a push-type clutch on this 993 engine since 1999. No problems. Clutch/pressure plate/flywheel assembly weighs in at about 18#.
Good luck |
biosurfer1 |
Jul 16 2013, 04:08 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
Too light? I think you just killed a little part of Ury with that comment (IMG:style_emoticons/default/biggrin.gif)
get off my lawn |
Jul 18 2013, 10:39 AM
Member Group: Members Posts: 168 Joined: 18-August 11 From: west coast Member No.: 13,462 Region Association: None |
how light is your flywheel?
I'd say it's somewhere between a medium silver and light gray, about the same color as yours. Not dark at all. |
Chris Pincetich |
Jul 19 2013, 10:20 AM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
My daily driver 914 turned cafe racer AX weekend warrior turned semi-daily driver has a lightened flywheel. It's 12 lbs I recall, behind a stock 1.7 TIV. When the engine is cold, it dies more often than it should. When warm, usually no problem. If you rev up in neutral, the drop back down can sometimes cause the engine to die. It just doesn't have that rotating mass to keep it smooth. I am really good at re-starting the engine no matter where/what. I like that my 914 is so sensitive to driver inputs w the light flywheel, turbo tie rods etc etc (IMG:style_emoticons/default/biggrin.gif)
Go for it (IMG:style_emoticons/default/beerchug.gif) |
GeorgeRud |
Jul 19 2013, 10:29 AM
Figure that the heavy outer starter ring is at the perimeter, I think this should work fine. Just don't put a 'puck' type clutch disc in the car if it's going to be a street driven car!
McMark |
Jul 19 2013, 11:26 AM
Cool. Sounds like this flywheel will be fine. I can always swap it out later if need be.
On to the next subject! (IMG:style_emoticons/default/biggrin.gif) These are the throttle bodies I will be using. They are from a Polaris 650. They line up perfectly with the intake ports, but I'll need to make adapters to make them fit. They're fairly large at 46mm, but I think they'll work okay. I need to transition from the intake port size (36mm I think) to the TB size (46mm). There are two options I can think of that I like. Have a flange cut from 1/2" aluminum and taper the inside. The other is to have longer transitions, but this would mean CNC milling. So there's the question: longer smoother transition intake, or short quick transition? (IMG:http://www.914world.com/bbs2/uploads/post-419-1368374534.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-419-1368374542.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-419-1368374550.jpg) |
JmuRiz |
Jul 19 2013, 12:04 PM
914 Guru Group: Members Posts: 5,488 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
With a 2.4 I'd go with longer to get a smidge more torque....
Those throttle bodies look really cool, can't wait to see what you do, and if you want to make another set...let me know. |
BKLA |
Jul 19 2013, 02:32 PM
scotty b |
Jul 19 2013, 03:22 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
What cams are you using ? (IMG:style_emoticons/default/confused24.gif)
Dave_Darling |
Jul 19 2013, 03:37 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Remember that the factory went to high-butterfly throttles in some of their race motors. I bet that was to allow them nice longer transitions in diameter, plus a longer distance after the injector squirted the fuel into the air stream for it to mix and vaporize.
I think you should go for the longer intakes. Can you do the machining yourself, or do you have to farm it out? --DD |
Mike Bellis |
Jul 19 2013, 06:23 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Longer runners will give you better low end torque. Shorter will move the torque curve higher typically.
What is your goal? Make sliding adjustable runners with O rings. Then tie a linear actuator to them. Control the actuator with an rpm counter to raise and lower as you drive... EASY! (IMG:style_emoticons/default/blink.gif) Mazda did this on racing engines. a NA 4 rotor did over 750hp. The RX-8 has multiple runners that are rpm/load controlled valves to lengthen and shorten the runners. |
McMark |
Jul 19 2013, 06:41 PM
Street engine. I like torque.
r_towle |
Jul 19 2013, 08:37 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
2 flanges cut.
Two pieces of tubing, cut stretched, welded. Then tig it all together... As I was thinking about it, you should be able to hammer a tube to get 10 mm out of one end.... I would think a bit of time on the sharp end of an anvil, with some patience, you could make the tube cone shaped.. Just a thought. Also, aren't the Ida carbs 46 mm? What kind of parts can you find using that stuff? Might want to contact Eurometrics, he specializes in the old carbs... |
Lo-Fi Version | Time is now: 27th September 2024 - 06:46 AM |
