qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
Damn, likely tightened 30 years ago!
Impact driver? big ass screw driver? This old motor is too greasy to risk heat (IMG:style_emoticons/default/welder.gif) i don't want to leave 1/2 in the case. Suggestions? |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
QUOTE(qa1142 @ Dec 4 2004, 04:22 PM) Damn, likely tightened 30 years ago! Impact driver? big ass screw driver? This old motor is too greasy to risk heat (IMG:style_emoticons/default/welder.gif) i don't want to leave 1/2 in the case. Suggestions? yep, you answered your own question (IMG:style_emoticons/default/smile.gif) I have a large screwdriver that I can put another screwdriver thru the handle for some extra torque.... good luck (IMG:style_emoticons/default/smash.gif) |
Rhodes71/914 |
Glacier ![]() ![]() ![]() Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 ![]() |
Biggest screwdriver you can fit in the slot, maybe a little penatrant (sp)
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
MAP torch. Works everytime. Everytime.
eeyore |
Senior Member ![]() ![]() ![]() Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None ![]() |
Use the largest craftsman screwdrive and BFH.
Stripped bolt removers work well too. http://www.sears.com/sr/javasr/product.do?...pid=00952166000 |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Try tightening them just a little before loosening them. This often breaks the corrosion bond and makes it easier to remove them. The same applies to brake line fittings.
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,166 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Very carefully (IMG:style_emoticons/default/biggrin.gif)
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I use a 1/2" drive, hand held impact screwdriver with the largest tip I can get in the screw. It too, works everytime. Like Chris said, try tightening it first.
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,215 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
I have a big ass screwdriver that has a hex section on the shaft right under the handle. I think it is made by SK Tools. You can put a box end wrench on it and really put some force behind it.
P |
morgan |
Member ![]() ![]() Group: Members Posts: 310 Joined: 28-March 03 From: milwaukee WI Member No.: 488 ![]() |
YA, Be carefull how you say cheese heads Wisconsin you know!!!
JOHN |
Dave-O |
Is winter done yet? ![]() ![]() ![]() Group: Members Posts: 511 Joined: 26-August 03 From: Minneapols, MN Member No.: 1,082 ![]() |
Attached image(s) ![]() |
Doug Leggins |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None ![]() ![]() ![]() |
Impact screwdriver works pretty well.
I also like a 3/8" drive screwdriver tool that I have. Can get alot of torque easy with this tool and a 3/8" ratchet. Attached image(s) ![]() |
tracks914 |
Canadian Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None ![]() ![]() |
QUOTE(vsg914 @ Dec 4 2004, 03:41 PM) I use a 1/2" drive, hand held impact screwdriver with the largest tip I can get in the screw. It too, works everytime. Like Chris said, try tightening it first. (IMG:style_emoticons/default/agree.gif) This is the best way to get them off. Tightening first only breaks the head off too many times. Heat damages wires and rubber. Impact screwdrivers are a must for any workshop and only cost about $10. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,992 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Just make sure the tip is the correct size for the slot in the screw.
The only screwdriver that I could find with a tip that was the right size was the largest one that my local Sears stocked. It's a really big mother... Not easy to use in the 914's engine bay, but not so bad when the engine is out. I replaced all the engine tin screws that I could with Allen-head screws. Much easier to install and remove!! --DD |
Kevin@ojai.net |
Member ![]() ![]() Group: Members Posts: 158 Joined: 9-July 03 From: Ventura & Chico, CA Member No.: 899 ![]() |
The progression of tools...
1st - box wrench 2nd - vice grips 3rd - smoke wrench -Kevin |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,556 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
QUOTE(Dave_Darling @ Dec 6 2004, 12:09 AM) I replaced all the engine tin screws that I could with Allen-head screws. Much easier to install and remove!! --DD Capt'n Crusty says that you will DIE because you didn't put the right screws back in the engine tin!!!! (IMG:style_emoticons/default/biggrin.gif) |
jwalters |
Sooo Close....... ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe ![]() |
(IMG:style_emoticons/default/wink.gif) The absolutely easiest and safest way of breaking the corrosion hold on any fastener is to whack it in the middle a couple of times with a hammer and drift--the shockwaves break-up all that is holding the fastener in.
I never use a impact, for over five years now--got damn tire of drilling and easy-outing, re-tapping,,etc. In your case, your big-ass screwdiver is the drift.....good luck>>> (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 21st June 2024 - 12:07 AM |
