wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
I'm see prices of $150, 350, and 500+ for new sway bars Just wondering, once on the car will there be a difference in feel? I really only want to spend $200.00, want adjustability, and 19mm for road only. Your opinions please. Make some sense out of this for me. Thanks John |
pilothyer |
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States ![]() |
Night and day difference.........drive one without, then drive one with.........you will agree and see the need for at least a front.
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Install the largest you can afford.
31mm here. KT |
shoguneagle |
shoguneagle ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California ![]() |
Trekkor is a racing nut who is having fun!!! You have to determine what your car is how your car is going to be used and then put in at least the front sway bar. The stock sway bar (19mm??) is very good for a road car; racing is something else ranging from 21mm to Trekkor's 31mm and may be then some.
Torsion bars and shocks must be considered. Back if you run a sway bar, the stock 16mm is good for the road (depends on who's view and experience); racing may use something else. At least run a front sway bar because it makes the difference "between heaven and hell" in driving, either racing or street. Enjoy finding out what your usage dictates and build one into your car, then have fun. Steve Hurt |
wndsnd |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,994 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The more expensive ones will move more smoothly, and use higher-quality hardware. There will be some difference in feel, and they will be somewhat less likely to have some sort of failure. (Though the cheaper ones don't have a huge failure rate; Rich Herzog blamed the wreck of his Six on a failure of one of those.)
--DD |
Trekkor |
yes, sorry.
For a road only, not tracked or autocrossed, driven at the speed limit car, a stock bar would probably be enough. If you plan on hammering the back roads like a wild man, which I suggest you don't, get a big bar. The big bar I added, transformed my car from a swaying questionable ride into a tight, dialed, on rails experience. I have it turned 1/3 to full stiff. Stock front torsion bars, Koni yellow's, 200# rear springs and stock rear sway bar installed. ![]() KT |
r_towle |
31mm?
Did you go get a piece of pipe from Home Depot? Rich |
chad newton |
Member ![]() ![]() Group: Members Posts: 110 Joined: 26-August 11 From: behind the red curtain Member No.: 13,491 Region Association: None ![]() |
Trekkor |
I wish (IMG:style_emoticons/default/smile.gif)
Smart Racing Products ( now Jerry Woods Enterprises ) It was About $800 if I recall. ![]() KT |
scott_in_nh |
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States ![]() |
Hi John, I think I gave you my 2 cents on this when we were on your boat, but I will post here for other comments (if any).
I put a stock front bar on my car last fall and have a rear bar that I have not installed. Before installation there was a fair amount of body roll and if you lifted mid turn the trailing throttle oversteer was substantial enough to require a noticeable decrease in steering input. After installation there was substantially less body roll and the trailing throttle oversteer was gone! It made a huge difference and I was very happy! Jump forward six months to this past spring when I started autocrossing. No matter what I did to the tire pressure (Goodyear Eagle GT's great street tire, substandard AX tire), the car plowed and the body lean was substantial! IMO, for the street the right thing to do at this point would have been to add the rear bar, but this doesn't work for AX as you will unweight the inside rear tire and spin it losing grip coming off of corners. So I went in search of used 140 lb rear springs, but found 165 lb progressive springs instead. These also ended up needing no helper springs or adjustable perches as they had about the same ride height as the 100 lb springs I removed! I was afraid of the way they would ride on the rough roads up here, but ended up improving the ride - firm but not harsh! I really like this setup for the street. On the AX course the car was so much flatter it was like a different car! In fact other drivers noticed the difference and asked what I changed. I could use the throttle to steer and tire pressure could actually be used to fine tune! If anything it has a touch too much oversteer right now that I am going to tune out by adding adjustability to the stock bar and stiffening it up a touch, but it sure is fun to drive this way! With 140 lb springs the stock front bar would probably be about perfect. So a big bar in the front without stiffening the back will result in an understeering car. I would suggest either stock bars at both ends with the 100 lb springs or the stock bar (or adjustable slightly larger bar) in front with 140-165 lb springs. I would only go to a big bar if I was going to go with 180+ lb springs and I don't think that is what you are looking for. |
wndsnd |
This is what I have.
The front A arms have the tabs I increased the rear springs to new 100 lb, I believe stock were around 80 New Bilsteins all around. I have ordered the front reinforcements. I will install these while I decide on a bar. My gut at this time tells me that a 19 or 22 will do the trick. I would not want to have to increase size at a later date. Want to do this once. Also, it looks like that bars are just mechanical levers, so why not buy the cheapest bar and install the best drop links for adjustability, wouldn't you still come out ahead in the long run or do you risk a mismatch of parts fitting. I don't see me putting a rear bar on the car. Thanks John |
r_towle |
So, if you are using this as a street car, 19mm is the way to go.
You new shocks will also add stiffness all around, they are gas charged, not oil filled like the OEM shocks and struts. With 180 lb rear springs, I have a 21mm front bar on full soft for the street. I have adjustable drop links that only get adjusted for autox, then remain in one position for the street. Nice part is after many years of playing with my suspension for both street and autox, I marked everything where I happen to like it. Takes me 30 minutes to do the following for an autox Drop rear ride height to autox setting Drop front height Move swaybar drop links to autox setting Replace wheels and tires with autox setup. So, my advice would be get a small bar that is adjustable. I would absolutely advise you to get a front bar, no matter what you are doing. Car does not perform correctly without at least a front bar, even the stock one works. Used stock bars are in the classifieds, and many upgrade to larger bars, so you should be able to find one somewhere. Rich |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
The 914 was 13 or 15 mm. I don't remember which as I gave it away. Bruce Stone can measure it for you plus it is stamped into one end.
I have a stock bar on the front of my six conversion (2.7L) with 140 lb rear springs, Bilsteins w/ adjustable perches on the rear and Koni Reds up front (911 struts). It corners nicely. I do have a 19 mm bar (911 front) that I will replace the stock one with someday. I also have a rear bar and have not installed it ... maybe some day. Car is not tracked. The best setup I ever put on a 914 was an SC front end complete with under body sway bar. Even though it was 22 or so mm, the way it is attached there is not as much deflection so the full rate is not realized. Flat as could be in the twisties. No need for adjustable drop links on a street car other than making sure the bar is not preloaded in rest position. Just a costly, unnecessary option. It's a torsion bar and the rate is determined by the diameter of the bar, length of the arms. Most importantly, the bar is most effective when it is horizontal to the ground plane and the arms are vertical and equal (bar not preloaded). Most effective place to tie in the drop links is at the ball joint for maximum available deflection with suspension movement, but that generally doesn't happen except on full race cars. Being able to adjust the arm length and keeping the drop links in a vertical plane is most effective, i.e., longer the arm for a given bar diameter, more torsional resistance. On the race cars, we had multiple attachment points on the arm and commensurate attachment points on the "A" arm so that the arm could be lengthened while keeping the drop links vertical. We had a rear bar set up in the same manner. On some tracks it was used and on others, we disconnected it. And yes, we used Detroit Locker rear ends. I'm done! |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
The most economical choice is a 19mm basic Weltmeister kit.
It won't have adjustable drop links but (as long as the car is well aligned) you won't notice the need for them unless you're setting up the car for competition. Differences between products which affect price/quality include: materials (fabricated steel vs cnc machined aluminum), attachment of the arms to the bar(square is the easiest to make but worst for long life/precision, splined is the highest precision/most expensive to mfr), drop link design/attachment, bushing material & mount design, bling anodizing, ease of adjustment, plain drop link bushings vs heim rods, etc. |
wndsnd |
The most economical choice is a 19mm basic Weltmeister kit. It won't have adjustable drop links but (as long as the car is well aligned) you won't notice the need for them unless you're setting up the car for competition. Differences between products which affect price/quality include: materials (fabricated steel vs cnc machined aluminum), attachment of the arms to the bar(square is the easiest to make but worst for long life/precision, splined is the highest precision/most expensive to mfr), drop link design/attachment, bushing material & mount design, bling anodizing, ease of adjustment, plain drop link bushings vs heim rods, etc. Thanks Chris, Struggling with the Brand, quality, price, thing. Everyone agrees on the front bar, no-one ever talks about features, benefits of the various brands. Ordered your bar reinforcements this morning. I will get them in. I have been cleaning the garage so I can start work on the car again, I gave it a rest for the summer. |
ChrisFoley |
Everyone agrees on the front bar, no-one ever talks about features, benefits of the various brands. I've dealt with just about every brand available. Stock 914 (early 911) 911 SC & Carrera Underbody Weltmeister (+ available upgrades) Tarrett Smart Racing TRG Tangerine Each has its advantages/disadvantages and each has its best purpose (although I think TRG and Smart Racing are roughly equivalent). Weltmeister is the entry level adjustable setup. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,439 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
don't forget the old H&H sway bars
gandalf_025 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,457 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States ![]() |
Hey John:
Good to see you are working on the car again.. I put a set of H&H bars on my car back in the mid 70's. I was able to drive to the house of the owner of H&H and pick them up at his front door. I bought the 19mm front and was back in a couple of weeks to buy a 16mm rear bar. |
wndsnd |
Hey John: Good to see you are working on the car again.. I put a set of H&H bars on my car back in the mid 70's. I was able to drive to the house of the owner of H&H and pick them up at his front door. I bought the 19mm front and was back in a couple of weeks to buy a 16mm rear bar. One of the last good days for the boat Al, Call me if you and Sue want to go out for a couple hours or so....... (IMG:style_emoticons/default/aktion035.gif) 978-270-4554 |
Lo-Fi Version | Time is now: 23rd June 2024 - 12:28 PM |
