Rear spring shock install question, what have I done wrong? |
Type 47 |
Aug 25 2013, 05:11 PM
Senior Member Group: Members Posts: 788 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
Installing new Bilstein shocks with 140 lb springs. took off stock springs with Koni's with a spring compressor. I didn't really need the spring compressors for the Bilstein's and now they slip off the bottom cradle. The Bilstein cradle is flat where the Koni's is more formed, like the top piece from the car.
What am I doing wrong here (note I installed them backwards to see it there was a difference). which reminds me...which end is up the small coils or the larger? (IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1377472264.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1377472264.2.jpg) |
jimkelly |
Aug 25 2013, 05:19 PM
that silver plate is upside down - I think
messix |
Aug 25 2013, 05:24 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
76-914 |
Aug 25 2013, 05:41 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,657 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Here is your exact setup. (IMG:style_emoticons/default/agree.gif) Once it's down and your not going neg G not a problem. Otherwise zip tie it on the top. You'll need to select a ride height on those. If you've got a 6 try the 4th perch. (IMG:style_emoticons/default/beerchug.gif)
Type 47 |
Aug 25 2013, 06:12 PM
Thanks guys (IMG:style_emoticons/default/headbang.gif)
I will filp the plate over... I have a 4, so no need to go to the other perch, however for the record I don't see how to move to the other perches...the plate just slides over them. |
messix |
Aug 25 2013, 07:55 PM
there should be a spilt ring [a wire that almost goes all the way around the shock body] that sits in the indents and holds the spring plate in place.
wndsnd |
Aug 25 2013, 08:44 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Your telling me these are upside down? Sorry for hijack.... Dammmmmmmmmm (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif) |
messix |
Aug 25 2013, 08:47 PM
Your telling me these are upside down? Sorry for hijack.... Dammmmmmmmmm (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/slap.gif) YES!!!!! |
zambezi |
Aug 25 2013, 08:52 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Another reason the silver perch should be the other way around, is that it captures the snap ring that is used for setting the ride height not allowing it to pop loose and the suspension would then collapse.
r_towle |
Aug 25 2013, 08:56 PM
Custom Member Group: Members Posts: 24,704 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Upside down guys. The clip won't car, but the spring will never stay centered with them upside down. |
Type 47 |
Aug 25 2013, 08:57 PM
Your telling me these are upside down? Sorry for hijack.... Dammmmmmmmmm (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif) no hijack at all very much a part of the conversation! |
wndsnd |
Aug 25 2013, 09:00 PM
Your telling me these are upside down? Sorry for hijack.... Dammmmmmmmmm (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/slap.gif) YES!!!!! Well good thing I looked at this thread. Wonder what else I installed upside down (IMG:style_emoticons/default/idea.gif) They need cleaning anyway.... (IMG:style_emoticons/default/wacko.gif) |
wndsnd |
Aug 26 2013, 08:43 AM
zambezi |
Aug 26 2013, 08:58 AM
The lower the clip the lower the ride height. I should not affect the firmness of the ride, the spring rate does that.
wndsnd |
Aug 26 2013, 10:23 AM
76-914 |
Aug 26 2013, 10:58 AM
It varies. This just establishes your ride height. Start at any position (maybe the 2nd) then lower the car move it a few feet, check your tire/fender clearance and general over height and adjust accordingly. (IMG:style_emoticons/default/beerchug.gif)
wndsnd |
Aug 26 2013, 11:06 AM
It varies. This just establishes your ride height. Start at any position (maybe the 2nd) then lower the car move it a few feet, check your tire/fender clearance and general over height and adjust accordingly. (IMG:style_emoticons/default/beerchug.gif) There is no drive train in the car yet so final adjustments can't be made. I was looking for a startiing point. I think I will just leave the rings where they are for now, and adjust once I get an engine in the car. (IMG:style_emoticons/default/beerchug.gif) |
wndsnd |
Aug 27 2013, 06:38 AM
Rich T, Racer Chris, Anyone? Where would you start with the ring on the spring level. Bottom? Mid? Thanks John |
ChrisFoley |
Aug 27 2013, 07:18 AM
I am Tangerine Racing Group: Members Posts: 7,976 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Start at the 4th groove from the bottom John.
You might switch to the 3rd groove but I don't think any lower is a good idea on a street car. |
wndsnd |
Aug 27 2013, 07:42 AM
Start at the 4th groove from the bottom John. You might switch to the 3rd groove but I don't think any lower is a good idea on a street car. Yo the man (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 18th January 2025 - 11:03 PM |
