ETMracing |
Newbie ![]() Group: Members Posts: 37 Joined: 22-August 13 From: frederick md Member No.: 16,288 Region Association: MidAtlantic Region ![]() |
Will be doing the BMW 320i front calipers on my 1970 914-4 2.0 but was wondering what can I use for a rear caliper? Thanks
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
http://www.pmbperformance.com/catalog.html
nice to support our vendors... + great products and tech advice |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Thanks Jim,
Here's the link to all of the 914 calipers: http://www.pmbperformance.com/914-brakes.html With the 48mm pistons and large pad up front the VB914-6 or a stock 914-6 rear caliper would be a perfect match bias and pad wise. This would give you a 38mm piston in the rear which would be the same as a 911RS, early 930, 911SC and 911 Carrera pad and piston size all around. Your bias would be 1.6:1 and perfect for what the factory established for the car. We have two pair of original -6 and -6/GT calipers for $1,200 and $1,500 respectively as well. |
pdlightning |
Member ![]() ![]() Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California ![]() |
Thanks Jim, Here's the link to all of the 914 calipers: http://www.pmbperformance.com/914-brakes.html With the 48mm pistons and large pad up front the VB914-6 or a stock 914-6 rear caliper would be a perfect match bias and pad wise. This would give you a 38mm piston in the rear which would be the same as a 911RS, early 930, 911SC and 911 Carrera pad and piston size all around. Your bias would be 1.6:1 and perfect for what the factory established for the car. We have two pair of original -6 and -6/GT calipers for $1,200 and $1,500 respectively as well. ALL I can say is see Eric at http://www.pmbperformance.com/catalog.html I bought the rear 308/V brake set up from them and they are beautiful ! Nice and honest people and great products. Only place to go. Direct bolt up and Vented rotors along with parking brake retention! |
Lo-Fi Version | Time is now: 25th June 2024 - 11:45 PM |
