jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
if I have both rear wheels off ground and trans in gear, engine does not turn over, both wheel just spin.
does it matter which wheel I have on the ground when trying to turn engine over via rotating a wheel? |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
How about holding one side with the parking brake, using a vice grip clamp, while you turn the other wheel?
It doesn't matter which side you turn as long as the other side is held firm. |
Bob L. |
Senior Member ![]() ![]() ![]() Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region ![]() |
I don't know if it matters but every time I read about it, it is the left rear that is free to turn.
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
One wheel has to be locked or on the ground and the tranny in a gear.
If I am using a lift, I put two lug bolt in one side and position a bar that rests on the arm of the lift between the lug bolts. I can then turn the other wheel to rotate the engine. |
jimkelly |
I just dropped entire car to the ground on wheel and tires. in neutral it rolls freely but in all other gears it won't move. something is bound up (IMG:style_emoticons/default/headbang.gif)
correction, not bound, just very hard to roll. and I have all spark plugs out. 307 sbc v8 engine. |
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
I just dropped entire car to the ground on wheel and tires. in neutral it rolls freely but in all other gears it won't move. something is bound up (IMG:style_emoticons/default/headbang.gif) correction, not bound, just very hard to roll. and I have all spark plugs out. 307 sbc v8 engine. Done it that way for years...use 4th gear, easier for wheels to push engine than in lower gears, then bounce, bounce, bounce....it'll move the engine. Slowly, slowly....catchee monkey! |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
Yup, that'll work. You can also get a manual starter switch, just two jumpers and a button, battery and solenoid, to use the starter to "bump" the engine into position while you watch the timing mark. Cheap. Any parts store. For lazy people like me.
r_towle |
Jack it up.
Take a piece of angle iron and drill two holes in it that line up with two lug bolts. Make the piece about 1.5-2feet long. Bolt it to the wheel at an angle to the floor. Much safer than trying to hope a piece lays in there and hold.. That acts as a brake for that wheel. Now put it in 5th gear and turn the other wheel backwards, that will spin the motor forwards. Rich |
jbyron |
Jamie ![]() ![]() Group: Members Posts: 128 Joined: 17-July 07 From: Ballwin, MO Member No.: 7,916 Region Association: Upper MidWest ![]() |
Rich - please forgive the stupid question, but why does turning the wheel backward spin the motor forward? Seems a forward gear like 5th would have motor and wheels going the same direction.
r_towle |
if both wheels are turning forwards, yes.
If you have one wheel locked in position on an open differential,, you need to turn the free wheel backwards to get it to spin the motor forwards. Go give it a try...you will see. rich |
jbyron |
Ah, got it. Relative to the backward-turning wheel, the fixed wheel is turning forward (even tho it's not actually moving). Makes sense.
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I use a 1" wooden dowel, or old hammer handle to stick thru the wheel spokes. The brake caliper stops the wheel from turning. If the wheel is off , use a clamp on the rotor and backing plate.
Lo-Fi Version | Time is now: 26th June 2024 - 04:47 AM |
