malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
Seems to me that the lower the better, right? I found this shot on Ebay and it got me thinking.
I have recently installed my e-brake and it really only comes up about 2 or 3 clicks. Not really even up over the threshold. Seems to make it easy to get in the car vs. this picture. I think this is too high. is there a "factory" spec.? Anyone else have thoughts? ![]() |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,996 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
When 'released' or fully down, it shouldn't allow the cables to engage the rear breaks and there shouldn't be any excess slack in the cable. As soon as you pull up on the lever it should immediately start to engage the brakes.
It's not rocket science. As long as the cables are adjusted properly so that both brakes get applied immediatly and evenly when the handle is pulled, you're good. It doesn't look like the cables are adjusted properly in the picture. |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,208 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
Venting clearance has to be set as well....otherwise it won't work.
malcolm2 |
Seems to me that the lower the better, right? I found this shot on Ebay and it got me thinking. I have recently installed my e-brake and it really only comes up about 2 or 3 clicks. Not really even up over the threshold. Seems to make it easy to get in the car vs. this picture. I think this is too high. is there a "factory" spec.? Anyone else have thoughts? ![]() My car below... actually 6 clicks and the handle is below the top of the seat. I cannot budge the car by pushing. My driveway is a slight hill and it holds great there too. I hope the guy above has kids, cause the RACK is coming and often with that handle. ![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 02:43 AM |
