Removing Seats, I can't find the spring? |
martinef1963 |
Dec 20 2004, 09:58 AM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
Gents - I've got a Haynes book and it makes reference to a spring after moving your seat all the way forward?
I have a 72 914 and am trying to get the seats off without having to remove the bolts that hold it down to the frame. Can someone tell me about these mysterious springs the Haynes manual refers too? Also - just let me know if I have to reove the two bolts on each rail to get the seat off. thanks, |
markb |
Dec 20 2004, 10:16 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
There is a spring you push up on when the seat is in the full forward position. It's on the opposite rail that the lever is. Just push the spring up, and pull the seat forward & off the rails. HTH.
Root_Werks |
Dec 20 2004, 10:21 AM
Village Idiot Group: Members Posts: 8,338 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
It isn't a coil type spring. yep, opposite side of the lever. Once all the way forward, it is a safety spring or rather a small metal tab you push up, or else it grabs a little metal pin not allowing the seat to go forward any further. It is on the rail on the seat side. You should get your finger greasy when you find it. Also, don't push hard forward against the seat will trying to push the little tab up. Move the seat all the way forward, then back it up just a tad, makes pushing the tab up easier. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
martinef1963 |
Dec 20 2004, 12:49 PM
THANKS - GENTS!
Lo-Fi Version | Time is now: 18th June 2024 - 07:27 AM |
