saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
I lost about 3/4 quart of oil on a recent 1380 mile road trip. Car didn't leak any oil before I left and didn't burn much either. Oil residue is heaviest around the oil filter area and the passenger side of the car, but I see traces of oil all the way from the top of the firewall pad to the rear valence. I may have more than one leak. Engine bay got hot enough that the fuel pump vapor locked on the trip. Pushrod tube seals look good. Does this sound and look like failing oil cooler seals? How big of a job are they to replace?
Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
Start with easiest first, pull that oil filter see if it split.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Oil pressure sender often sprays onto the firewall
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I agree with Brant. Pressure sender is on the top. If it's dry, work your way down.
Kirmizi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None ![]() |
Eliminate the simple stuff on the top side first. Pressure sender (check between the plastic body and metal threaded portion) and the oil filler gasket and bail. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) also know your other areas to check then clean it and watch it. if an area is tough to reach use some brake cleaner. autozone has some lo voc vanilla scented stuff that actually smells good. there are a few plugs on the front of the engine, oil pump, etc. any oil leak you have one of these cars will go everywhere so it's hard to tell if it's oil coated. don't forget the valve cover gaskets.
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Or, you popped a oil galley plug ...
(IMG:style_emoticons/default/idea.gif) |
Cap'n Krusty |
In my experience, a blown oil galley plug or blown oil cooler seals will effectively dump ALL the oil RIGHT NOW. Like in seconds at cruising RPM. My money's on the oil pressure switch.
The Cap'n |
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
Ferg |
In my experience, a blown oil galley plug or blown oil cooler seals will effectively dump ALL the oil RIGHT NOW. Like in seconds at cruising RPM. My money's on the oil pressure switch. The Cap'n (IMG:style_emoticons/default/agree.gif) Rod D popped one on the way out of Moab RRC years back, you could follow the oil trail, lucky he only went 30 yards or so. |
r_towle |
Head vents?
Seems they spurt more on the highway. |
saigon71 |
Did some investigation and found my oil pressure sender to be loose and leaking where the plastic insert meets the metal base. The whole plastic piece turned freely in the base. Ordered a new one from Pelican and hope to get a few more drives in before the salt hits the road.
Thanks again 914 world! Attached image(s) ![]() ![]() |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
Opportunity to install a VDO dual sender and oil pressure gauge (IMG:style_emoticons/default/idea.gif)
gothspeed |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None ![]() |
Opportunity to install a VDO dual sender and oil pressure gauge (IMG:style_emoticons/default/idea.gif) +1 ... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 09:15 PM |
