FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
We need a new rear bearing for the chump car.
I noticed FAG are 38 and SWF are 82 from the bird board. Is the SWF better quality? Will the concours judges ding us? :-) John |
dlestep |
I am smilin'... ![]() ![]() ![]() Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States ![]() |
FAG (Fat American Guy)= 38 - cheaper, but I don't swing that way.
SKF (Southern Kinky Female) = 82 - a little more of everything ! I have used both. They are equal in wear. However you must look at the material specifications to really know. Check Ball bearing material and process. Check Race material and process. ~ http://www.fag-skf-nsk.com/en/channel/fag-...ements-569.html This site has the normal mumbo-jumbo, but take notice of the ethic of design by failure mode determining material & processes. |
dlestep |
Remember, these days, e v e r y t h i n g is made in China.
Even though SKF is a Swedish company, they get their stuff from the same people using 142 + vendors. Go german if you can. They make the best bearings. |
Jeff Hail |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 ![]() |
Have used just about every brand of sealed cartridge bearings known. I've smoked a good FAG and banged an SWF. Had both last and both fail. Both are decent brands. Luck of the draw. Based on average cost I go with the FAG but have been known to find SWF's cheap once in a while.
FourBlades |
Thanks Dave! Checking the material used is beyond my pay grade. If people have had positive experiences with FAG it would help to know. John |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Check the car you are putting them into...
FAG will be perfectly fine. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
The bearings seem to be shifting to different parts of the world depending on the production run. I have seen both FAG and SKF made in Germany, France, Spain and Mexico. These changes have been occurring from the 1980's to present. Both are good bearings and equal in quality. The price seems predicated on previous name recognition.
FourBlades |
wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
Don't know where I bought them without looking at a gazillion receipts,
But I put in two and one is bad out of the box Now I need to redo a trailing arm 50/50 who it is. |
FourBlades |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
In the end, installation technique makes the biggest difference, hands down.
The Cap'n |
FourBlades |
In the end, installation technique makes the biggest difference, hands down. The Cap'n I like how the Pelican article says you need to use the Brute Strength and Ignorance (BS&I) method to remove the old bearing... (IMG:style_emoticons/default/smash.gif) From the Pelican article it seems like pressing on the outer race of the bearing to install the bearing into the trailing arm, and then only pressing on the inner race when installing the hub are keys to not damaging the new bearing. Anything else to watch for? John |
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
https://www.youtube.com/watch?v=T6CxhlpOvng The master himself explains it nice and methodically for us (IMG:style_emoticons/default/smile.gif) |
Jon B |
Member ![]() ![]() Group: Members Posts: 73 Joined: 28-September 13 From: Vista, CA Member No.: 16,448 Region Association: None ![]() |
In the end, installation technique makes the biggest difference, hands down. Here is how Porsche recommended doing it. Rear axle bearing is installed using tool P302. ![]() Wheel hub is drawn into bearing using tool P298b. Tool is first threaded onto axle shaft. ![]() Tool P298b wheel hub installer Tool P302 bearing press pad ![]() Jon B. Vista, CA |
rhd914 |
Newbie ![]() Group: Members Posts: 44 Joined: 11-November 03 From: Australia Member No.: 1,332 ![]() |
Ok, so split the difference and get one of each.
DEC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 630 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany ![]() ![]() |
Remember, these days, e v e r y t h i n g is made in China. Even though SKF is a Swedish company, they get their stuff from the same people using 142 + vendors. Go german if you can. They make the best bearings. SKF = Schweinfurter Kugellager Fabrik A very old German industrial company These parts are DIN-Parts with the same specs from any vendor in Germany DIN=Deutsche Industrienorm=German industrial norm (standard) |
Jon B |
SKF = Schweinfurter Kugellager Fabrik A very old German industrial company SKF Svenska Kullagerfabriken AB Gothenburg, Sweden http://en.wikipedia.org/wiki/SKF SKF does have manufacturing plants in Germany. Jon B. Vista, CA |
Downunderman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand ![]() |
Don't use SNC made by the Frogs. I have had a bad experience.
Jon B |
Don't use SNC made by the Frogs. I have had a bad experience. SNR Societe Nouvelle de Roulements Annecy, France http://fr.wikipedia.org/wiki/NTN-SNR_Roulements Excellent bearings Now part of the NTN Group Jon B. Vista, CA |
r_towle |
In the end, installation technique makes the biggest difference, hands down. The Cap'n I like how the Pelican article says you need to use the Brute Strength and Ignorance (BS&I) method to remove the old bearing... (IMG:style_emoticons/default/smash.gif) From the Pelican article it seems like pressing on the outer race of the bearing to install the bearing into the trailing arm, and then only pressing on the inner race when installing the hub are keys to not damaging the new bearing. Anything else to watch for? John Think about the bearing and its construction, along with all the friction and force you create while installing the unit. When pressing it into the hub, all the friction is on the outer race. If you press on the inner race, you stand a very good chance of twisting, bending, or racking the bearing. Then, when you go to install the inner stub axle, all the friction is on the inside of the inner race.... So, hold that in place when pressing. I remove the trailing arm, bring it to the press, and do it there. Rich |
Lo-Fi Version | Time is now: 25th June 2024 - 11:33 PM |
