Best way to add heat to a Subaru conversion? |
CptTripps |
Dec 16 2013, 08:30 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
I would like to add heat and defrost to my Subaru conversion, but I'm not sure the best way to do it. Now, I'm no expert on the ventalation system of these cars, but I was hoping to have something simple like 2 discrete motors. One for the vents on the dash, and another for the defrost.
The stock heat blowers are intact on the car, but I don't believe they're hooked up at all, since the PO had a SB350 installed. That motor is going bye-bye, and I'm not sure the best way to add something to replace it. I don't need fire shooting out of the vents like my Land Rover, just enough to get the windscreen clear and take the edge off of a cool night. I see a few aftermarket blowers that I can put in-line with the heat tubes, but how should I GET the heat? Is thee a way to do it from the water in the radiator? |
bfrymire |
Dec 16 2013, 08:47 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
I would like to add heat and defrost to my Subaru conversion, but I'm not sure the best way to do it. Now, I'm no expert on the ventalation system of these cars, but I was hoping to have something simple like 2 discrete motors. One for the vents on the dash, and another for the defrost. The stock heat blowers are intact on the car, but I don't believe they're hooked up at all, since the PO had a SB350 installed. That motor is going bye-bye, and I'm not sure the best way to add something to replace it. I don't need fire shooting out of the vents like my Land Rover, just enough to get the windscreen clear and take the edge off of a cool night. I see a few aftermarket blowers that I can put in-line with the heat tubes, but how should I GET the heat? Is thee a way to do it from the water in the radiator? How about a hot rod heater? Speedway motors has one... --brett |
bulitt |
Dec 16 2013, 08:59 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Do a search under Marks914. He put an oil cooler in the fan blower box and ran coolant through it via a valve.
McMark |
Dec 16 2013, 09:30 PM
I'd look at a motorcycle oil cooler, mounted in front of the tubes in the engine bay and plumbed in the water system. Fabricate a shroud to connect the cooler to the round pipe and put a fan on it. One on each side probably. Wouldn't need a valve in them, IMHO. Just control the fans. And use the stock diverter valves to control direction.
Mike Bellis |
Dec 16 2013, 09:34 PM
Resident Electrician Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I did an oil cooler in the fresh air box. I did a how to here somewhere. I use the stock fav and control the water valve with the dash controls.
Tilly74 |
Dec 16 2013, 10:06 PM
Member Group: Members Posts: 96 Joined: 5-June 12 From: Springfield, MO Member No.: 14,522 Region Association: None |
For my subie swap I plan to modify my fresh air box and install an a/c evaporator and ...haven't worked out the details yet, but I think my next step is a long day of digging through small vehicle dashboards at a pick-n-pull. The ultimate goal would be functioning heat and a/c through the fresh air box controls. For heat I want to use something like this and direct the heated air into the fresh air box where the factory heat came in from heat exchangers.
BIGKAT_83 |
Dec 16 2013, 10:22 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Like mine here. Both heat and AC.
Still have to finsh this before next summer (IMG:style_emoticons/default/sawzall-smiley.gif) Bob |
Mike Bellis |
Dec 16 2013, 10:23 PM
Here's my heater thread...
http://www.914world.com/bbs2/index.php?sho...led+guys+bellis Here's marks914... http://www.914world.com/bbs2/index.php?sho...c=70317&hl= |
gryphon68 |
Dec 17 2013, 08:03 AM
Member Group: Members Posts: 61 Joined: 2-October 13 From: SE Michigan Member No.: 16,462 Region Association: Upper MidWest |
Considering this myself.
This is where I'm leaning. Please feel free to shoot holes in my theory. Using a expansion tank with radiator cap as the highest point in my coolant system. With the addition of a couple more inlets and outlets or some fitting tee's you can have a small electric pump circulate water through the heater core branch and return it to the tank. Heater core and heater core branch lines need to be kept lower than the top of this tank. Ideally this would probably be mounted on the rear wall of the front trunk. You could either run one leg of the engine-to-radiator coolant lines through the tank, or what would probably be cleaner would be a large tee in one of the engine-to-radiator coolant lines running to the expansion tank. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.moroso.com-16462-1387289019.1.jpg) |
DBCooper |
Dec 17 2013, 08:22 AM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Wow, Bob, EXTREMELY sanitary! And you actually carry that broom around? Wow, that's above and beyond. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/poke.gif)
(IMG:http://www.914world.com/bbs2/uploads/post-194-1387254058.jpg) Seriously, that's excellent, are there parts details in one of your threads? |
mepstein |
Dec 17 2013, 08:57 AM
914-6 GT in waiting Group: Members Posts: 19,694 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Like mine here. Both heat and AC. Still have to finsh this before next summer (IMG:style_emoticons/default/sawzall-smiley.gif) Bob Exactly what I want to do when I build my subie conversion. factory appearance. Looks awesome! |
nsyr |
Dec 17 2013, 12:41 PM
Because I Can Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 |
Like mine here. Both heat and AC. Still have to finsh this before next summer (IMG:style_emoticons/default/sawzall-smiley.gif) Bob What are you using in there?????? |
CptTripps |
Dec 17 2013, 01:35 PM
Yeah, I'm waiting for that explanation too! That looks like a hot setup.
Chris H. |
Dec 17 2013, 01:48 PM
Senior Member Group: Members Posts: 4,053 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Is this what you used Bob?
mikesmith |
Dec 17 2013, 01:54 PM
Member Group: Members Posts: 202 Joined: 5-September 13 From: SF Member No.: 16,354 Region Association: Northern California |
The unit you linked is one of the Vintage Air under-dash units; very different from the one in Bob's pic. The VA guys believe very strongly in recirculate-only setups, none of their units are set up to pull fresh air.
I think we all want to know what he's done there. 8) |
Chris H. |
Dec 17 2013, 02:05 PM
Ah OK. I was trolling all his old threads...we'll just wait then!
gryphon68 |
Dec 17 2013, 02:14 PM
The unit you linked is one of the Vintage Air under-dash units; very different from the one in Bob's pic. The VA guys believe very strongly in recirculate-only setups, none of their units are set up to pull fresh air. I think we all want to know what he's done there. 8) That is the picture/link Bob originally posted here. |
CptTripps |
Dec 17 2013, 02:17 PM
Attached image(s) |
badmiata |
Dec 17 2013, 02:34 PM
Newbie Group: Members Posts: 47 Joined: 21-June 07 From: Houston, TX (Clear Lake) Member No.: 7,826 Region Association: None |
I have seen the under dash ones. Renagade, Pelican and what not sell them but its a whole kit compressor and all. I would be happy with something like that if I could use the compressor from the subaru enigine.
ThePaintedMan |
Dec 17 2013, 02:40 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Bob's setup is really cool. Would love to find out what it is exactly, but also how he figured out what would work there.
On another note, someone with CAD experience and a 3D printer could probably design something similar, once the proper heater core and fan were identified. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 11th January 2025 - 06:42 AM |
