surface rust paint inhibitor question |
rosenfe |
Dec 18 2013, 10:15 AM
Senior Member Group: Members Posts: 564 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
ive done search for a product recommended in previous threads to spray on as a surface rust inhibitor.cant find it,?anyone know what it is,or their favorites?
malcolm2 |
Dec 18 2013, 10:25 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
ive done search for a product recommended in previous threads to spray on as a surface rust inhibitor.cant find it,?anyone know what it is,or their favorites? Might not be your application, but I use POR-15. 3 step process of cleaning, etching and painting. You can thin it and spray it if you want. Clark |
wndsnd |
Dec 18 2013, 06:32 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Not so much a spray on but you could put it in a spray bottle.
I like a product called Rust Mort by SEM Wire brush as clean as you can, wipe down and apply. After it is dry you can etch prime or POR15 It kind of turns the rust to like a galvanized metal and I have never had a problem with primer adhering to it |
malcolm2 |
Dec 18 2013, 07:03 PM
ive done search for a product recommended in previous threads to spray on as a surface rust inhibitor.cant find it,?anyone know what it is,or their favorites? Might not be your application, but I use POR-15. 3 step process of cleaning, etching and painting. You can thin it and spray it if you want. Clark My hell hole, after my ugly welding And after the POR-15 process. It won't hurt it, but the sun will change the color. They recommend a light sanding and any top coat. |
carr914 |
Dec 18 2013, 07:38 PM
Racer from Birth Group: Members Posts: 122,772 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Eastwood makes one
rhodyguy |
Dec 18 2013, 08:07 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,198 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
exisitng surface rust? a product named Mar-hyde is excellent. a convertor similar to ospho(sp?).
wndsnd |
Dec 18 2013, 09:17 PM
ellisor3 |
Dec 19 2013, 08:32 AM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
wndsnd |
Dec 19 2013, 08:38 AM
ThePaintedMan |
Dec 19 2013, 08:40 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
After using POR 15 on several projects, I think I'd switch to Eastwood as well in the future. I used POR on a beetle in college on clean metal and had no problems. Tried it with my car this time around again, on clean metal (scuffed it and even did the rest of the prep instructions including marine clean and "prep and ready") and all I got were fisheyes everywhere. I think they must have changed the formula, but I was not impressed.
Eastwood's product is apparently much easier to use, so that's what I would go with next time around. |
rosenfe |
Dec 19 2013, 10:45 AM
it was the eastwood product i was looking for,thanks.anyone familiar with miracle pain from mercedessource?wonder if its por15 in disguise.?
LotusJoe |
Dec 19 2013, 11:41 AM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I have used corroseal in many applications with good results. Easy to apply and easy cleanup.
I have even used to to coat ballast tanks on some of my tugboats and it has held up under some very harsh conditions. |
rosenfe |
Dec 19 2013, 12:36 PM
I have used corroseal in many applications with good results. Easy to apply and easy cleanup. I have even used to to coat ballast tanks on some of my tugboats and it has held up under some very harsh conditions. you have tugboats?as in more than one?wow,any pics? |
r_towle |
Dec 19 2013, 12:43 PM
Custom Member Group: Members Posts: 24,680 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
phosphoric acid is the main ingredient that I found for most of the rust converting products.
I bought a gallon of that at Home depot for far less than all the magic juice sold by the pint. It works find, just clean it with water afterwards, dry it out and paint. rich |
LotusJoe |
Dec 19 2013, 04:09 PM
I have used corroseal in many applications with good results. Easy to apply and easy cleanup. I have even used to to coat ballast tanks on some of my tugboats and it has held up under some very harsh conditions. you have tugboats?as in more than one?wow,any pics? Had a company here on the west coast with 9 tugs and barges transporting petroleum products from San Diego to Dutch Harbor. Sold the fleet in 2005. This the tug Mister Fred; typical of our tugs. 4,000 hp. |
rosenfe |
Dec 19 2013, 05:47 PM
I have used corroseal in many applications with good results. Easy to apply and easy cleanup. I have even used to to coat ballast tanks on some of my tugboats and it has held up under some very harsh conditions. you have tugboats?as in more than one?wow,any pics? Had a company here on the west coast with 9 tugs and barges transporting petroleum products from San Diego to Dutch Harbor. Sold the fleet in 2005. This the tug Mister Fred; typical of our tugs. 4,000 hp. impressive,thanks for the pic |
Bulldog9 |
Dec 19 2013, 05:59 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
I've used POR 15, and Eastwoods system, both work, but the best I've used is called miracle paint from a site called mercedessource . https://mercedessource.com/store/do-it-your...ng-kent-bergsma
This is definitely NOT POR 15 in disguise, if you get it on your hands and it dries, you are cutting it off or waiting for the skin to die and it falls off. POR 15 you can peel off scrape off acetone off. Not this stuff... |
Lo-Fi Version | Time is now: 5th January 2025 - 01:24 AM |
