M22x1.5 to coolant sensor adapter? |
mikesmith |
Jan 17 2014, 05:16 AM
Member Group: Members Posts: 202 Joined: 5-September 13 From: SF Member No.: 16,354 Region Association: Northern California |
Trying to fit a 3/8NPT or M12x1.5 coolant sensor into what I think is a standard M22x1.5 fan switch fitting (Renegade radiator), but having no luck locating an adaptor to suit either.
Anyone have a source? Or an alternate suggestion? |
bulitt |
Jan 17 2014, 08:32 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Trying to fit a 3/8NPT or M12x1.5 coolant sensor into what I think is a standard M22x1.5 fan switch fitting (Renegade radiator), but having no luck locating an adaptor to suit either. Anyone have a source? Or an alternate suggestion? MSC |
mikesmith |
Jan 17 2014, 11:48 AM
Thanks; the "ISO port" nomenclature is new so that helps with the searching.
I'm worried that, with the way that the port is located and the geometry of the GM sensor, I'll wind up with the active part of the sensor in an air pocket because it won't poke out far enough. Ideally, I'd be able to find something like this: http://www.sealconusa.com/reducer-nc-round-metric.html with the right thread, but so far it looks like I'd be better off hoping the port is really M25... |
McMark |
Jan 17 2014, 06:34 PM
Get an aluminum M22 to AN adapter (Summit or Setrab) and cut the AN portion off, drill/tap to the size you need.
Here's one. M22 to AN-6. AN-6 should be plenty small to give you the 'meat' you need to drill and tap. |
bulitt |
Jan 17 2014, 07:16 PM
keep looking
Mike Bellis |
Jan 17 2014, 07:47 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
How about plugging that hole and get this?
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.proimporttuners.com-10496-1390009640.1.jpg) http://www.proimporttuners.com/parts/kia/f...CFQWTfgodlE4Acg |
worn |
Jan 17 2014, 08:51 PM
can't remember Group: Members Posts: 3,290 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Thread hijack, but does anyone know wher you can get the tube nut for the standard Porsche oil line at 30m 1.5 for 20 mm tube? They all seem to jump to around $50 when you reach this size and this size only.
Now back to the worthy thread still in progress. The expertise made me seize the opportunity (IMG:style_emoticons/default/hijacked.gif) |
mikesmith |
Jan 18 2014, 12:37 AM
Mark - funny you should suggest that, I'd just ordered a couple plus a 3/8NPT tap off eBay an hour earlier. I went -8 rather than -6 (3/8 is .675 and -8 should be ~.5 ID), so I hope my math is good.
Mike - thanks, but a) they're all too big for the hot side hose, and b) the stickers that come with it would almost certainly attract the wrong sort of attention. 8) |
Mike Bellis |
Jan 18 2014, 12:51 AM
Mike Bellis |
Jan 18 2014, 12:53 AM
mikesmith |
Jan 24 2014, 12:13 AM
Just like a bought one, only different.
Lo-Fi Version | Time is now: 27th September 2024 - 12:35 PM |
