anyone fitted power steering to a 914 |
returf |
Jan 29 2014, 04:20 AM
Member Group: Members Posts: 67 Joined: 15-August 12 From: New Zealand Member No.: 14,806 Region Association: Australia and New Zealand |
Has anyone fitted power steering to their 914? if so what rack did you use?
mepstein |
Jan 29 2014, 06:44 AM
914-6 GT in waiting Group: Members Posts: 19,679 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Why? Unless you put monster tires on the front, 914 steering is light and precise. I would check over all front suspension and possible overhaul the steering rack if you're having steering issues.
wndsrfr |
Jan 29 2014, 07:45 AM
Senior Member Group: Members Posts: 1,442 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Why? Unless you put monster tires on the front, 914 steering is light and precise. I would check over all front suspension and possible overhaul the steering rack if you're having steering issues. (IMG:style_emoticons/default/agree.gif) Take a quick look at your caster setting....makes a big difference if its excessive. |
dlestep |
Jan 29 2014, 07:55 AM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
Isn't that like, ...ugh, leather toilet paper ?
76-914 |
Jan 29 2014, 08:20 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,650 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Maybe a one armed driver or an electric 914 with a trunk full of batteries. Otherwise (IMG:style_emoticons/default/agree.gif) with the others.
914GT |
Jan 29 2014, 09:13 AM
Senior Member Group: Members Posts: 1,101 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Here's a V8 conversion fitted with a power steering rack, as well as power brakes. There are a few pictures of the underside of the car and the power steering pump.
http://www.cardomain.com/ride/2303120/1975.../photo-gallery/ Guy T. |
stugray |
Jan 29 2014, 12:43 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
If you really wanted to retrofit PS to a 914, look into the Subaru BRZ steering system.
It is electric and all of the motor & support equipment is in the steering column. No fluids, or pumps required. There have been a LOT of totaled BRZs/FR-Ss so an entire steering column can probably be found cheap. |
dlkawashima |
Jan 29 2014, 01:00 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
Thread in the Paddock ... http://www.914world.com/bbs2/index.php?showtopic=210814
CptTripps |
Jan 29 2014, 01:07 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Power Brakes: I can see that being useful.
Power Steering: Unless you're running real wide slicks, I can't see a lot of people needing it. End of the day: With enough time/money, anything is possible. |
euro911 |
Jan 29 2014, 01:16 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
If you really wanted to retrofit PS to a 914, look into the Subaru BRZ steering system. Hmmm ... makes one wonder why there are so many 'totaled' (IMG:style_emoticons/default/laugh.gif)It is electric and all of the motor & support equipment is in the steering column. No fluids, or pumps required. There have been a LOT of totaled BRZs/FR-Ss so an entire steering column can probably be found cheap. |
stugray |
Jan 29 2014, 02:49 PM
QUOTE Hmmm ... makes one wonder why there are so many 'totaled' Maybe it is because they are marketing a mid $20k car to teenagers that has one of the best power to weight ratios of any car in it's class. The electric PS only "assists" at certain times. It is still a direct link to the rack & pinion so could be retrofitted to other systems fairly easily. |
r_towle |
Jan 29 2014, 02:55 PM
Custom Member Group: Members Posts: 24,680 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
The Prius steering system could be made to work.
There are other electric motors out there, just need to fabricate up a new steering linkage. Otherwise, same thing I told Randal...go to the gym, its cheaper. Larger steering wheel helps Proper seat orientation also helps... All of our cars have the wrong seating position for race driving....so look at the ergonomics. rich |
euro911 |
Jan 29 2014, 04:09 PM
You missed my sarcasm
I'm old school ... I like metal rods and gears in my steering, and metal rods or cables for my throttle control, not a microsoft windows app (IMG:style_emoticons/default/shades.gif) |
r3dplanet |
Jan 29 2014, 10:14 PM
Senior Member Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
Just want to point out that the Mazda Miata also uses electric power steering. They're at least as dependable as hydraulic power steering, probably more. The only problem is that the electrics are hooked into the onboard computers so it isn't like you can just pull one from a junk yard and hook it up. FYI.
-marcus |
Mike Bellis |
Jan 29 2014, 10:35 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Andyrew |
Jan 29 2014, 10:37 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Power Brakes: I can see that being useful. Power Steering: Unless you're running real wide slicks, I can't see a lot of people needing it. End of the day: With enough time/money, anything is possible. ^ This.. Power ABS brakes would be a godsend in the 914. Power steering? Meh, you couldnt tell a difference. 255's up front and no issues... Slicks in a parking lot might be another story, but seriously its no heavier than any of my power steering cars. |
BIGKAT_83 |
Jan 30 2014, 07:36 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Do a search here. Driveablity did a Toyota electric power steering converion on his SBC owered car.
Dr Evil |
Feb 2 2014, 12:31 PM
Send me your transmission! Group: Members Posts: 23,035 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
FYI, Mini Coopers have an electric motor driven hydraulic pump that would likely easily transplant. (IMG:style_emoticons/default/smile.gif)
Bills914-4 |
Feb 2 2014, 03:16 PM
Member Group: Members Posts: 311 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
Lo-Fi Version | Time is now: 4th January 2025 - 10:57 PM |
