vw505 |
Member ![]() ![]() Group: Members Posts: 228 Joined: 17-April 03 From: San Antonio, TX , Navy retired Member No.: 579 Region Association: None ![]() |
I am trying to use the tins of my 1.8LT and put them on my 2056cc . Some don’t seem to fit right, is it just simply because the 96MM pistons are larger?
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
1.8 top tins won't work on a 2l head
The pistons are bigger, the cylinders are not. |
vw505 |
I have 2L top tins, the ones I am having trouble with are the smaller ones that go down the sides of the motor.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
The only differences are the top tins and the lower air guides. Everything else is the same.
The Cap'n |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
vw505 |
Got them in, they needed some tweeking.
zig-n-zag |
Member ![]() ![]() Group: Members Posts: 182 Joined: 18-May 06 From: Hawaii Member No.: 6,024 ![]() |
Back in the day, the 98mm Okrasa/Oettinger aluminum cylinders
had 4 to 6 (I forget) more full-sized fins than the regular cast-iron ones. One guy I know ground the fins down so he wouldn't give away he was running those high-dollar parts with massaged tins! He cooked that motor good. |
Lo-Fi Version | Time is now: 29th June 2024 - 06:10 PM |
