Jerry75914 |
Member ![]() ![]() Group: Members Posts: 124 Joined: 13-October 08 From: Half Moon Bay, CA Member No.: 9,640 Region Association: Northern California ![]() |
Hello all! It has been a restoration in progress for several years, and mechanically, this car is just about done, runs and drives great.
All it really needs is a paint job, and a few touches to the interior to be an overall outstanding car. Be aware, the original engine has been replaced with a higher horsepower 2270cc engine (built by our own McMark). If you want an all original car, this is not it...although it could be put back to stock fairly easily. Price is $15,000.00 firm. Contact Jerry at 650-274-7645. Car is located in the San Francisco bay area. Engine: Raby 2270 kit professionally built and installed by Original Customs in Sonoma, CA, approximately 6K miles. Flywheel, clutch and fan (all new) balanced. New dual Weber 44IDF carbs, Keith Black pistons, Mallory unilte distributor, MSD6AL, high output coil, additional external oil cooler, Optima sealed battery, new starter, new accelerator and speedometer cables, SSI 2.0 liter heat exchangers, Triad dual tip exhaust Brakes: new Zimmerman rotors, calipers professionally rebuilt by PMB Performance, Porterfield R4S pads, new brake lines, new ATE 19mm master cylinder Transmission: rebuilt with new synchros for 1st – 3rd gears, new 1st / reverse slider and dogteeth. Approximately 10K miles since rebuild. New Rennshift shifter and all bushings replaced. New clutch cable. Front / rear Suspension: new Bilstein shocks / struts, Elephant Racing poly bronze bushings in front, Weltmeister 140 lb. springs, turbo tie rod kit, new ball joints, new front wheel bearings, 21mm Weltmeister sway bar, Interior / Body: Bumpers back-dated to early chrome style with new bumper top for the front bumper. Interior stripped down to metal, new rust preventative, two layers of sound deadening, Engman chassis re-enforcement kit, new carpet kit, new mats, new reproduction door cards, CHT, Oil temp, oil pressure gauges added to stock appearance group. Center tunnel plastic fuel lines replaced with stainless steel. Center console re-upholstered. Electrical: re-conditioned original alternator, fuse box replaced with modern spade fuses ![]() ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 23rd June 2024 - 12:40 PM |
