Megasquirt dyno day |
Bleyseng |
May 28 2003, 05:31 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Blair and I made it to the Blood Enterprises shop and met up with Dave Hunt just in time. Kevin showed up a few minutes later and we got to watch Dave convince the owner that this is the day scheduled to do the dyno work and we weren't going away.
Finally, things were straighten out and the car got on the dyno. Dave was running his laptop to tune the car while the dynoguy was operating the car on the dyno. Made several baseline runs so Dave could calibrate his O2 sensor software to the dyno set up. Then the first real pass the 74 2.0L made 73.5hp, not too bad. Then the work started with multiple runs adjusting the A/F curve trying to get the mix close and flat. Had to big spikes in it that had to be fixed. Almost 2 hours later the last pass produced 80.5hp and a better fuel curve without the big spikes. I test drove the car and it was really smooth, lots of torque. Geoff |
SirAndy |
May 28 2003, 05:34 PM
Resident German Group: Admin Posts: 41,806 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Bleyseng @ May 28 2003, 04:31 PM) 80.5hp and a better fuel curve without the big spikes. 80.5 at the wheels. not bad! any (stock) dyno-sheets to compare to? Andy |
airsix |
May 28 2003, 05:47 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Were you guys just working on wide-open-throttle pulls, or did you do tuning under light loads too? Weren't the tuning problems Dave was having regarding light-load cruising? Did this get worked out? 80.5hp at the wheels sounds great for a 2.0 w/ stock internals. Brad/others, what's a baseline for comparison? (ie what will a stock d-jet 2.0 put to the ground?)
At any rate, congrats to Dave on the megasquirt conversion sucess. I'd say 80.5hp to the wheels is sucess indeed. -Ben M. |
Brad Roberts |
May 28 2003, 05:53 PM
99.8 fully tuned Djet set on kill. Header/K+N/Euro P+C's with timing set at 30deg. on 91 octane... with quiet muffler (street legal) Open made 101 hp
80 some odd is perfect for a mid-high mileage engine with stock P+C's. I think Mueller and I tuned something like 73-75 hp in less than 1 hour with the MS. Didnt really try because Mueller didnt want to spend the cashola... I have tested bone stock high mileage engines with headers (no tuning) and have seen 75-80 quite frequently. I think he done good.. << Gomer Pyle voice B |
Aaron Cox |
May 28 2003, 06:12 PM
how much does dyno time run an hour?
Bleyseng |
May 28 2003, 08:01 PM
Here it was $125 an hour. I think the other shop is at $90 and hour.
Geoff |
Jeff Krieger |
May 28 2003, 08:05 PM
Unregistered |
QUOTE(SirAndy @ May 28 2003, 04:34 PM) QUOTE(Bleyseng @ May 28 2003, 04:31 PM) 80.5hp and a better fuel curve without the big spikes. 80.5 at the wheels. not bad! any (stock) dyno-sheets to compare to? Andy Here are the recent dyno results for Ed Carlson's 2.0. He rebuilt his motor in '99 and it is stock except for the fact that he had it balanced and he has a Crane points replacement system. The stock d-jet seems to do a very good job. (IMG:http://www.914world.com/pix/(basically)stock2.0rw-hp.jpg) |
Andyrew |
May 28 2003, 11:15 PM
Hooo doggies, some numbers to look forward too!! BTW, Once I get the stupid
engine in, what the drive train HP loss percentage? I'll be doing some tests on a gtec, and tuning with that. (if I can tune) What else should I do while the engine is out (to the engine)? I am converting back to fuel injection, and I will be cleaning the engine as best I can. I also will be putting on aluminum valve covers I got for 20 bucks. Anything else I can do? I have a very limited budget, so im not going to do a full blown rebuild. Im going to take the tin off, clean the grime off the engine and tin, and paint the tin. I will also be fixing the battery tray rust, what should I use to take off the surface rust so when I weld up metal and Por-15 it? Thanks guys! |
rhodyguy |
May 29 2003, 05:57 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
it was interesting, and there were a few humorus moments. i think that the guy running the test was more accustomed to verticle gate shifters in big american iron. one run he put it in reverse. the car started crab crawling sideways across the drums. ' WHOA, YOU'VE GOT THE CAR IN REVERSE!!" geoff, blair and i were standing behind the the car at the time (IMG:style_emoticons/default/ohmy.gif) . "ah, you guys might want to stand off to one side". who says the shifters in these car can be a bit vague. don't feel bad about the money we throw at our cars. there was a nova/chevell there w/ a buick turbo v6 grand am engine, more other mods than i can remember. $40-50 g min. when did the topics/ replies start running so wide across the screen?
kevin |
airsix |
May 29 2003, 10:49 AM
QUOTE(rhodyguy @ May 29 2003, 03:57 AM) when did the topics/ replies start running so wide across the screen? It does that when someone posts a large picture. Resize your pictures to something like 640 pixels wide or less before posting, and everything will stay nice - no horizontal scrolling. -Ben M. |
Jeff Krieger |
May 29 2003, 11:06 AM
Unregistered |
How do you resize pictures? Do you need a special program? When I used the software that came with my HP scanner to crop the edges of a pic, the size ballooned from about 300k to over 2.0 mb! Same thing happens when I try to reduce the dimensions of a pic.
Bleyseng |
May 29 2003, 11:12 AM
I use Adode Photoshop Elements to resize pics for the web
open the pic go to Image>resize set the dpi to 72, then the size to 640 hit ok then File>save to web, set it to jpeg, then adjust it to high, and the file should be under 200k, then ok. There you have a small for the web jpeg pic, about 640 which is about a 5x7pic. You can do the avatars here too. Geoff |
Jeff Krieger |
May 29 2003, 11:24 AM
Unregistered |
Sounds expensive (I don't have PhotoShop). I guess you guys are just going to have to suffer. (IMG:style_emoticons/default/tongue.gif)
Brad |
May 29 2003, 11:47 AM
Unregistered |
Resize your pics. Use IrfanView. Its free.
Dont make the "Bad Brad Moderator" come out in me. You wont like me when I'm a Moderator. B |
SirAndy |
May 29 2003, 11:54 AM
if you have Win2000, it comes with the "Microsoft Photo Editor" which lets you resize pictures easily.
the program is called "PhotoEd.exe" and can usually be found here: C:\Program Files\Common Files\Microsoft Shared\PhotoEd open the pic with it, go to the "Image" then "Resize", select "Pixels" as the "Unit" and specify a new size ... then save ... Andy |
seanery |
May 29 2003, 01:59 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I'm sure you can find a "demo" version of photoshop on Kazaa.
Gint |
May 29 2003, 05:05 PM
Mike Ginter Group: Admin Posts: 16,093 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Go get IrfanView. It will do a lot of cool stuff.
Dman |
May 29 2003, 05:18 PM
Member Group: Members Posts: 163 Joined: 18-February 03 From: Sacramento CA Member No.: 311 |
There are a ton of programs out there that will resize pictures, Photoshop, photo deluxe, image expert, photo impact illustrator etc.
Chances are if you ever purchased a digital camera the software that comes with the camera will include a photo editor. |
anthony |
May 29 2003, 05:31 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Microsoft Photo Editor sucks!!! Actually it works ok and has a decent interface but the quality of the jpegs it makes sucks. Irfanview will produce a much higher quality end product. Irfanview is a little harder to learn though. Some of the things it will do are not intuitive. I also like Irfanview's batch features. For example you can easily could reduce, sharpen, and save a whole folders worth of photos.
Bleyseng |
May 29 2003, 05:51 PM
Photoshop Elements is $99 and it does tons of editing. Well worth the $$
Course I take tons of pics with the digital and Monique has won 2nd prize ($300) in a local photo contest. I have them printed at Ofoto.com, all online uploading/ordering. Geoff |
Lo-Fi Version | Time is now: 21st September 2024 - 06:45 PM |
