> Strange electrical problem
914itis
post Mar 29 2014, 12:34 PM
With the ingnition off, when I move the wiper switch to the one position, my horn beeps. If I turn the ignition off, it stops. (IMG:style_emoticons/default/confused24.gif)
mintyish
post Mar 29 2014, 02:04 PM
QUOTE(914itis @ Mar 29 2014, 11:34 AM) *
It could be your steering column upper bearing breaking down - it's Nylon and falls apart with age and then allows the horn circuit to earth through the steering column.
Try wiggling the wheel up and down and see if you have any free play in the upper bearing.
You can get replacements and it's an easy fix...
Good luck
John
post Mar 29 2014, 02:45 PM
914-6 GT in waiting
Only drink German beer. Otherwise your car will be pissed off and honk at you
messix
post Mar 29 2014, 02:48 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
With the ingnition off [ok], when I move the wiper switch to the one position, my horn beeps. If I turn the ignition off [ I thought you said it was off already?], it stops. (IMG:style_emoticons/default/confused24.gif)
this post doesn't make any sense. please read edit above
post Mar 29 2014, 03:02 PM
Resident German
Did you cross any wires from the horns and the parking lights?
With the ignition off, the parking lights are operated with the turn signal lever ...
914itis
post Mar 29 2014, 03:07 PM
QUOTE(messix @ Mar 29 2014, 04:48 PM) *
Correction, when I turn the ignition on., it stops.
914itis
post Mar 29 2014, 03:12 PM
QUOTE(SirAndy @ Mar 29 2014, 05:02 PM) *
That's the first thing that came to mind but it's not the signal lever. I didn't do any electrical work.
Just reinstalling my dash gauges .
- Lo-Fi Version Time is now: 15th January 2025 - 12:57 AM
