Ray Warren |
Member ![]() ![]() Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None ![]() ![]() |
The fittings at the bottom of the fuel tank. One is smaller than the other.
Does it matter which one is used for supply? |
double-a |
Senior Member ![]() ![]() ![]() Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest ![]() |
yes. iirc, on early tanks, supply is the larger of the two. inside the tank, it has a filter on the inside, a kind of mesh "sock" that keeps crap from heading downstream. the return line should be the small one. i believe that the later tanks had two fittings of identical size. ~a |
Lo-Fi Version | Time is now: 26th June 2024 - 12:40 AM |
