-JR- |
Life goes faster at 150MPH ![]() ![]() Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 ![]() |
All aftermarket cams or special grinds all seem to require a bolt on cam gear.
So I'm wondering what the difference is between the stock cam gear and the aftermarkets ones that are !NOT! a straight cut gears? I suppose the real root of this question is if I could grind off or dill out the rivets on a stock gear and bolt that gear onto an aftermarket cam. Thanks! -JR- |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
According to oil pump selection you **can**...
But ONLY do it if your gear has a "C" suffix part# and is aluminum. alot of the cam gears were magnesium with a "B" suffix and they suck, they strip all the time.... I highley recommend updating to the 30mm TI pump and a new, modified cam gear (for oil pump clearance)while its apart. The stock pump sucks. |
-JR- |
Jake, when you say... "oil pump selection" what do you mean?
What is this cam gear mod for oil pump clearance? (I've included a pic of what I have) Do you know where I can get one of those 30mm pumps? Thanks! (IMG:http://www.jamesrenfrew.com/ftp/incoming/Temp/205.jpg) Here is the reason for the tear down... (IMG:http://www.jamesrenfrew.com/ftp/incoming/Temp/207.jpg) What are these modifications for? Any ideas? (IMG:http://www.jamesrenfrew.com/ftp/incoming/Temp/208.jpg) |
Jake Raby |
That smoked journal is the very first one to run out of oil! Thats why you need a modified pump upgrade.
I have the cam, modified gear and pump that you need. |
-JR- |
Any prices there Jake?
Jake Raby |
PM me please.
Lo-Fi Version | Time is now: 22nd June 2024 - 08:50 PM |
