brooks944 |
Member ![]() ![]() Group: Members Posts: 241 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States ![]() |
My new 914 has gaps between the heat exchanger and the exhaust, which isn't a stock one. Is it supposed to be welded to make a tight fit?
Thanks, Rick |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
There is a gasket, and you may want to use two for each side.
brooks944 |
Thanks, where do you get them?
r_towle |
Pelicanparts
GPR parts Automotion Any of the standard 914 vendors |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
get the correct ones for your application. 2.0 differ slightly from 1.7/1.8 versions and late he are completely different. if you're unsure which to buy post a picture of the he currently on your car.
Lo-Fi Version | Time is now: 26th June 2024 - 02:42 AM |
