Boxster transmission adapter plate, Relocated starter |
r_towle |
May 10 2014, 02:09 PM
Custom Member Group: Members Posts: 24,656 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Guys,
In response to another thread about subarus, someone posted a link about a shop in AZ that is making an adapter plate kit to bolt up a boxster transmission to a Subaru motor. Wondering if he sold a kit, or just did all the work, I reached out to him. He does in fact sell a kit which requires milling out some of the bell housing, but then you can mount a starter. Assuming much of the flywheel and clutch would not work, this might be a good place to start for someone who races, wants a more modern transmission, a cable shifter, and would like to remain all Porsche.... Naro... Link to site for pricing etc. http://www.boxsterengineconversion.com/par...ith-prices.html Attached thumbnail(s) Attached image(s) |
naro914 |
May 10 2014, 07:05 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
Did you ask if it work with a Porsche 3.2 engine?
r_towle |
May 10 2014, 07:12 PM
It's a flat plate of aluminum.
Holes need to be drilled for whatever motor you choose. The hard part will be clutch and pressure plate, and flywheel. It will work, yes, but the setup he sells is for a Subaru.. All the dimensions for the pressure plate offsets would be wrong.. Bet he could figure it out for you,,,,some really nice work on his site. Rich |
precisionchassis |
May 12 2014, 10:56 AM
Member Group: Members Posts: 99 Joined: 26-July 10 From: Gilbert, AZ Member No.: 11,979 Region Association: Southwest Region |
It will only work with a Subaru engine and uses stock style Boxster/Cayman clutches. If you wanted to use an air cooled Porsche engine, you would be on your own.
rick 918-S |
May 12 2014, 10:01 PM
Hey nice rack! -Celette Group: Members Posts: 20,816 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
That is really not hard to do. I made my adapter plate for the Alien in my garage with a center punch and a hand drill. Many thousands of miles crossing the country is proof it works. Just takes some planning.
bulitt |
May 13 2014, 05:41 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
I bet KEP could do this quickly. He already has plates for the Trans, and plates for the Suby. Just some CNC programming?
CptTripps |
May 13 2014, 06:17 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
This could be real interesting, but I wonder if it wouldn't be easier at the end of the day to just find a way to cram the Boxster motor in there WITH the trans that it's already mated to.
If you are mounting a Subaru motor to it, you're saving weight and with the right mods, getting (about) the same HP. The Subie trans when converted to 2WD is pretty solid, and there are a lot more/easier mods/parts for the setup. I'm glad to see people engineering other ways around this, but I am still happy with the path I took on using the Subie motor/trans. |
mepstein |
May 13 2014, 06:26 AM
914-6 GT in waiting Group: Members Posts: 19,642 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
This could be real interesting, but I wonder if it wouldn't be easier at the end of the day to just find a way to cram the Boxster motor in there WITH the trans that it's already mated to. If you are mounting a Subaru motor to it, you're saving weight and with the right mods, getting (about) the same HP. The Subie trans when converted to 2WD is pretty solid, and there are a lot more/easier mods/parts for the setup. I'm glad to see people engineering other ways around this, but I am still happy with the path I took on using the Subie motor/trans. I don't think people are thrilled about boxter motors. At least the ones with the IMS issues. Blown motors at 60K is one reason boxters sell so cheap. I like the idea of putting a subie motor into a blown boxter but also think there would be interest to adapt a boxter trans to an aircooled 6 in a 914. It would give us another option to the typical 915 trans swap. |
CptTripps |
May 13 2014, 07:10 AM
... think there would be interest to adapt a boxter trans to an aircooled 6 in a 914. It would give us another option to the typical 915 trans swap. I agree fully with this part. It gets pretty tight back there though. The boxster trans is pretty big IIRC. If you had a 3.6 or something extreme in there, I can see needing the better trans. The cable-shift alone makes the mod worthwhile if you ask me. Even sitting in my car, not running, shifting through the gears is tight and quick. I can't wait to get it on the road and see what it's like to have a 914 where I don't need to "hunt" for a gear. |
r_towle |
May 13 2014, 07:11 AM
That was kinda my point.
Subaru to Subaru is simple and well thought out. Using a boxster transmission with the relocated start....well that was the first time I had seen anyone do more than just talk about the idea. He went to the length of actually doing it. Could someone copy him, maybe....but why bother. He sells a kit....albeit it's just for a Subaru motor... Taking his kit one more logical step to mate the boxster transmission to an aircooled porsche motor is a big plus and might sell even better. For us, it may be a real and viable alternative to dumping money into an old 914 transmission that in the end still lacks a lot of the more modern things we expect. Having a modern tranny solution is really interesting. |
naro914 |
May 13 2014, 07:21 AM
^^ Agreed
I have no interest in a Subaru motor. I want to keep it Porsche. There are A LOT of 914/6 conversions out there - I would suspect many more than Subie conversions. i would think if we could find a reliable, fairly simple way to mate up a Boxster trans to those, it would be a big win. |
r_towle |
May 13 2014, 07:28 AM
And this seems really close.
Boxster transmission Starter relocate Boxster clutch Just need to setup a flywheel for your application, and drill different holes for your motor....which would be the same for any of the six cylinder motors... |
ClayPerrine |
May 13 2014, 12:33 PM
Life's been good to me so far..... Group: Admin Posts: 15,947 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Looking at the specs in PET and online, the Boxster and 964/993 clutch disks are teh same diameter. Both cars use a dual mass flywheel. But the Boxster uses a push type clutch, and the 964/993 uses a pull type.
I don't have any of them here, but I suspect the bolt pattern is the same for the pressure plate attachment. So IF you could bolt the Boxster pressure plate to the 964/993 flywheel, then there is no custom clutch parts needed. But you still need the adapter plate for the trans, and a place to mount the starter. The adapter plate may make the engagement of the pilot bearing a little short, and the throwout bearing stroke a little longer. I would use the aftermarket racing flywheel to eliminate the dual mass setup, and use the aftermarket clutch throwout bearing that incorporates the slave cylinder into it. A spacer could be made the same thickness as the adapter plate for it. (IMG:style_emoticons/default/idea.gif) |
BIGKAT_83 |
May 14 2014, 12:34 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
And this seems really close. Boxster transmission Starter relocate Boxster clutch Just need to setup a flywheel for your application, and drill different holes for your motor....which would be the same for any of the six cylinder motors... Looks a little harder than that. From the picture thread and damn nice. |
Chris914n6 |
May 15 2014, 02:08 PM
Jackstands are my life. Group: Members Posts: 3,423 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I don't suppose someone has a CAD file of the 914 engine on Boxster trans bolt holes they would care to share?
I don't have a Boxster trans available and wanted to see if was feasible to redrill my Nissan adapter plate. |
bulitt |
May 15 2014, 02:56 PM
The pics above are from member "221kw914" - Alex.
I pm'ed him to see if he has a template. Also, I emailed KEP. They manufacture an adapter for boxster to SBC & LS engines but not Suby or Porsche. |
got914? |
Oct 17 2014, 02:20 PM
Member Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
Chris914n6 |
Oct 20 2014, 03:47 PM
Found this on Rennlist.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i94.photobucket.com-431-1413841627.1.jpg) Nothing larger than a 228mm clutch will fit inside the 4 bolt pattern. The adapter plate above pretty much explains it. 1" Flywheel spacer to stock 240mm pieces. There are VW/Audi sprung discs to choose from. The Box/VW/A PP might bolt up to that 993 fly or be T/O bearing compatible. As for me, I've got a built tall gear box and only 260hp so not really worth all the R&D time and cost. Hydraulic clutch should fix my only big issue. Maybe do cables as the rod is a tight fit around the oil pan. |
Mike Bellis |
Oct 20 2014, 09:10 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I'm running an 11lb VW/Audi lightened flywheel with a SPEC Stage 3 clutch. It works with both my Boxster 5 & 6 speed trannys. I also run the cheap ($) VW slave cylinder instead of the expensive ($$$) Porsche unit that is exactly the same except the hydraulic fitting. 034 Motorsport sells fitting adapters with a plug and play -3AN end. It makes it easy to install with a Wilwood or Howe type master cylinder.
Here is a pic of a 901 and Boxster 5 speed with the axles lined up. The center line distance from the axle center to the edge of the bell housing is shorter on the Boxster. A 1" adapter would put the tranny in better alignment with the engine in stock location. With the axles lined up, the end of the tranny is in about the same place. |
El Vikingo Tropical |
Dec 5 2014, 02:18 PM
Newbie Group: Members Posts: 39 Joined: 10-October 14 From: Canary islands Member No.: 18,003 Region Association: None |
And this seems really close. Boxster transmission Starter relocate Boxster clutch Just need to setup a flywheel for your application, and drill different holes for your motor....which would be the same for any of the six cylinder motors... Looks a little harder than that. From the picture thread and damn nice. Do have any news about the 3.6L engine fitted to the Boxster trans? |
Lo-Fi Version | Time is now: 21st December 2024 - 10:10 PM |
