mr914 |
914 Hillbilly ![]() ![]() ![]() Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None ![]() |
Pulling apart that Aluminum case 2.0 motor in anticipating to sell it and cant seem to get one of the heads off.
Motor has been sitting for 20 plus years and rotates freely. 4 heads came off with a little more than a ketchup bottle thump. 1 head came off with the cylinder attached The other one, wont seem to budge. Made sure all washers were removed. been soaking with PB Blaster for a couple of days BTW: motor had been sitting for several years and a mouse had made a nest on top of that particular cylinder. Hence - Mouse motor... Any suggestions? (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) ![]() ![]() |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I would suggest filling up the cyl with a little oil while at BDC, reinstall spark plug, close valves and rotate motor.
If you did it adruptly (and if there is any compression left) it might pop the head loose. But if you have already disassembled all the other cylinders, then that might not be easy. |
Justinp71 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,588 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None ![]() ![]() |
More power! (IMG:style_emoticons/default/smash.gif) When I did mine I removed the entire assembly with the 3 heads and cam towers, some light prying was necessary, just be careful not to scratch any important surfaces. If your pulling the barrels off the pistons, maybe see if you can pull the head and barrel of together and then try to knock the barrel off with a mallet. |
mr914 |
Stugray = you may be on the right track.
With no cams etc... Leak down tester and let compressed air move it a bit. Attached thumbnail(s) ![]() |
mr914 |
5 of 6 cylinders heads off
3 cylinders off |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Put a spark plug back in it at BDC and rotate the crank to TDC. Might pop it off.
mr914 |
If I was going to do that, shouldn't I remove the other pistons first?
Mike Bellis |
Jon B |
Member ![]() ![]() Group: Members Posts: 73 Joined: 28-September 13 From: Vista, CA Member No.: 16,448 Region Association: None ![]() |
Check to make sure all cylinder head nuts are removed.
With rubber hammer, or metal hammer against block of wood, hit head sideways in both directions several times. It should break bond (not fins). Jon B. Vista, CA |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,040 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
Wouldn't the rope trick work? Get piston at BDC, thread a rope into the cylinder through the spark plug hole and then rotate engine. Never done it myself but I've heard it works.
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
do not pry against the cylinder fins, they will break off easily. . If you're sure all 4 head nuts and washers are off, hit it with a RUBBER mallet. . it's better to tap many times than one hard time. . .
I was taught to hit on the top and bottom only which is the way the wrist pin/crank rotates. . . if you hit sideways it can bend the rod. . |
Jon B |
Nine_14 |
Member ![]() ![]() Group: Members Posts: 311 Joined: 30-August 12 From: Germany Member No.: 14,873 Region Association: Germany ![]() |
If none of the above given suggestions helps, bring the piston to the lowest point,
fill cylinder with water and put the whole package in the freezer for a night and hope that the soft spot is the head. |
mr914 |
mr914 |
Confirmed last night that all of the nuts and washers are off.
Using a 1# plastic tipped dead blow hammer with quite a bit of force. One of the other heads came off with the cylinder attached. This one is stuck on both sides Penetrating OIL is doing its thing, since last night and will get back to it after 7 tonight. So far. 1) using a wood block and a bit more force sounds like first option. 2) Putting plug back in and rotating to see if compression will move it. 3) use leak down tester with cylinder at either TDC or BDC and let compressed air do its thing. Will give those a try. Thank you for your suggestions. |
Scott S |
Small Member ![]() ![]() ![]() Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 ![]() |
Wouldn't the rope trick work? Get piston at BDC, thread a rope into the cylinder through the spark plug hole and then rotate engine. Never done it myself but I've heard it works. (IMG:style_emoticons/default/agree.gif) I did this last week to a Jag motor - works awesome. Just enough push to pop it off. |
Nine_14 |
If none of the above given suggestions helps, bring the piston to the lowest point, fill cylinder with water and put the whole package in the freezer for a night and hope that the soft spot is the head. That's a creative approach. I had never heard of that one. I never used this method to remove cylinder heads, but it is working fine if you want to remove dents from motorcycle tanks. |
injunmort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States ![]() |
gently heat the seam with a torch or heat gun, then tap on it again with the dead blow. the expansion from the heat should free it up. good luck
get off my lawn |
Member ![]() ![]() Group: Members Posts: 168 Joined: 18-August 11 From: west coast Member No.: 13,462 Region Association: None ![]() |
M-80 in the spark plug hole.
hey it works on cats and frogs ....... (IMG:style_emoticons/default/poke.gif) |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,517 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Anyone that would do that to any animal is a sick fuck and should seek professional help.
Lo-Fi Version | Time is now: 24th June 2024 - 07:40 AM |
