partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
Lizard skin probably isn't something to try and use in the cab in place of sound deadener, but would be ok to use in the engine bay, and rear trunk?
Bob L. |
Senior Member ![]() ![]() ![]() Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region ![]() |
I thought Lizard skin was a sound deadener. They also have thermal insulation.
effutuo101 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California ![]() |
I used both the thermal and sound deadening in the cabin and on the firewall. Shouldn't be an issue.
partwerks |
I wonder which would be easier to apply, like Dynomat, or lizard skin?
I would imagine lizard skin is a spray on type? Maybe both sides of the firewall, and rear trunk? Not sure about front turnk? |
914_8 |
Newbie ![]() Group: Members Posts: 40 Joined: 3-November 13 From: Saugus, Ca Member No.: 16,601 Region Association: Southern California ![]() |
I use Lizard skin routinely at work. DO NOT apply it where it can get wet(engine comp) it will damage it. Also if you decide to put the sound and ceramic coatings on, apply the sound damper first.
914four |
Senior Member ![]() ![]() ![]() Group: Members Posts: 510 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States ![]() ![]() |
I use Lizard skin routinely at work. DO NOT apply it where it can get wet(engine comp) it will damage it. Also if you decide to put the sound and ceramic coatings on, apply the sound damper first. Has anyone used this in the engine bay or had trouble with the "wet" areas? |
effutuo101 |
Haven't hit the road yet. I did paint over mine so I think it is sealed.
Also, I live in San Diego. So, not much water. |
partwerks |
Are there any other choices that might be comparable to lizard skin, or sound deadener, for putting in the cab, and trunks?
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Are there any other choices that might be comparable to lizard skin, or sound deadener, for putting in the cab, and trunks? Lizard skin is super easy to apply. I sprayed it in the cab on the firewall. If you want to go cheap and effective, you can use "Ice Mat" from a roofing supply store. It is a sticky, thick, rubber-ish membrane. It can be applied like dynamat. It is slightly less dense and will need to be thicker (more layers). Lizard skin is still easier since it sprays on. It's water based and will need time to dry. You could also use bed liner spray. It will take out some sound resonance but will also need to be thinker than dynomat. |
partwerks |
I wonder how the lizard skin compares to the dyno mat for lessening the sound?
Mike Bellis |
partwerks |
Or mufflers that are more quiet, this time around.
Tilly74 |
Member ![]() ![]() Group: Members Posts: 96 Joined: 5-June 12 From: Springfield, MO Member No.: 14,522 Region Association: None ![]() |
I just don't understand how anyone could skin a lizard they're so cool! This is Mango our baby bearded dragon. She loves the sun and car rides so naturally the 914 is perfect...too bad her owner is taking forever to get anything done.
![]() Attached thumbnail(s) ![]() |
partwerks |
I stumbled across a couple options.
From some of the comments, one being a cheap good version called Raammat, and the other is where you can DIY Lizardskin? http://www.stangnet.com/mustang-forums/thr...parison.774952/ http://www.binderplanet.com/forums/showthread.php?t=96613 http://www.digitalcorvettes.com/forums/sho...ead.php?t=81933 |
partwerks |
I wonder if using lizard skin on the interior side of the targa top, under the carpet, would be favorable for helping with sound?
Lo-Fi Version | Time is now: 25th June 2024 - 09:29 PM |
