rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,978 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
I have a new Bowlsby alternator wiring harness I bought off of a member here. Can I install it without removing the alternator? At quick glance it doesn't appear possible, but figured it was worth asking before going forward.
Thanks! |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,992 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I think you may be able to remove the rear cover of the alt without removing it from the car, but I'm pretty sure it will be a lot easier to deal with if you just get it out of there.
If you can remove the engine tin screws (always a big "if" for me!) the left-front piece of tin comes off separately just to allow for alternator removal from under the car without having to just from above to below and back a hundred times. --DD |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,821 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
The tin screws can be a challenge. I think you have to pull the alternator to get at the wires. There's cover on it that needs to be pulled off to access the wires. Hardest part is holding the alternator in place while you slide the main bolt back in
Lo-Fi Version | Time is now: 20th June 2024 - 06:22 AM |
