rmdinmd |
Member ![]() ![]() Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States ![]() ![]() |
I am thinking about picking up one of the HF hydraulic presses and wondering if the 12 ton would be all I would probable need or should I go for the 20 ton one.
I wouldn't use it much, but there are times when things have to be pressed in. Like my sons wheel bearings when they went bad. I also have read that with the 914 there are ways around a press but that a press would probable make things easier. what are your thoughts on this guys? Waste of money? 12 ton plenty or might come up short? 20 ton? |
motorvated |
Member ![]() ![]() Group: Members Posts: 281 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains ![]() |
I am thinking about picking up one of the HF hydraulic presses and wondering if the 12 ton would be all I would probable need or should I go for the 20 ton one. I wouldn't use it much, but there are times when things have to be pressed in. Like my sons wheel bearings when they went bad. I also have read that with the 914 there are ways around a press but that a press would probable make things easier. what are your thoughts on this guys? Waste of money? 12 ton plenty or might come up short? 20 ton? Years ago I bought a 12-ton press Harbor Freight. Used it to press out/in ball joints. It worked great. Since then I haven't used it much, but every time I needed it, it was invaluable to have it there. Just used it to change the bearings on my rear control arms, and to press new longer lug studs into the front and rear 5-lug hubs. If you have the garage space for it, I'd get one. Never needed anything beefier than the 12 ton, even though I've loaded up the 12-ton pretty heavily. Just my 2 cents. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,521 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
+1 on the 12 ton. And they don't require any more space than a drill press! I think I paid $99 for mine with the 25% coupon.
JStroud |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California ![]() |
I have the 12 ton, don't use it much, but the times I do it's very handy. Better than a vise or a BFH, very controlled. Pressed out the shaft from a rear trailing arm the other day, like it was greased, took about 30 seconds.
The 12 is all you would probably need working on these cars, but if you can afford it the 20 would obviously be better. |
rmdinmd |
Thx guys. (IMG:style_emoticons/default/biggrin.gif)
it sounds like the 12 will be all I will most likely need. like you all said, I don't expect to use it much; but like my sawzall and hammer drill, when you need them, they are great to have. |
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
Never used the 12 ton press. I have an older 20 ton. I use it all the time. I say go big. 20 ton is usually more than enough. I have wanted more.
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
Get the 20 ton. . it is on sale in a current flyer for $155
colingreene |
Senior Member ![]() ![]() ![]() Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California ![]() |
I have a 12, ive loaded it up pretty hard but it usually does the job.
but if you have the space for the 20 do that. My garage is what you would call space limited. |
Lo-Fi Version | Time is now: 29th June 2024 - 09:41 AM |
