Mwood |
Member ![]() ![]() Group: Members Posts: 56 Joined: 11-February 13 From: Bay Area Member No.: 15,509 Region Association: Northern California ![]() |
Hey I am getting some cv axles back from machining in a couple weeks,
is there a part number for the cup/thrust washers that go on the inside of the joint? or have any idea where they can be purchased I have no idea where mine went and I will need them for the rebuild. need 2 also has anyone got a regular snap ring to work instead of those annoying C rings that hold the joints on the front side? thanks in advance Mitch |
JFJ914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States ![]() ![]() ![]() |
Hey I am getting some cv axles back from machining in a couple weeks, is there a part number for the cup/thrust washers that go on the inside of the joint? or have any idea where they can be purchased I have no idea where mine went and I will need them for the rebuild. need 2 also has anyone got a regular snap ring to work instead of those annoying C rings that hold the joints on the front side? thanks in advance Mitch Dealer |
dangrouche |
dangrouche ![]() ![]() ![]() Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None ![]() |
removed
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
If you buy the right tool the C clips are not a problem. I bought K D tool long ago for $ 12 that works great. It has knurling
On the flat tips so it does not slip. Some cv's do use snap rings. |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Bruce, does that to have a part number on it? Iwill look for one
Mwood |
Found my washers, good advice on the tool
I also wonder about a part number |
Lo-Fi Version | Time is now: 26th June 2024 - 11:00 AM |
