swooshdave |
Member ![]() ![]() Group: Members Posts: 184 Joined: 11-June 14 From: Portland Member No.: 17,475 Region Association: Pacific Northwest ![]() |
I crawled under the car to check some things out. The major concern was the oil piddles on the ground.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403417122.1.jpg) The engine was mostly dry and the transmission was wet. But that could just mean it was coming back from the engine so after taking the picture I went to cleaning. (IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403417122.2.jpg) The right bank of engine had some oil on it. Are transmission leaks common? Maybe the pushrod tubes are leaking? |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,514 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Clean it well then let it run whilst parked. Driving down the road will blow the oil back. After it has run a while check again. Common areas are the push tube seals which are cheap and easily replaced; valve cover gaskets, ditto; oil cooler seals; oil pressure sender; oil pressure sender. Both the oil pressure sender and oil cooler are on the right side.
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
My guess is the front main seal. Unless you drive backwards all the time. Then I would guess the rear stack gasket.
swooshdave |
My guess is the front main seal. Unless you drive backwards all the time. Then I would guess the rear stack gasket. (IMG:http://www.914world.com/bbs2/uploads_offsite/i237.photobucket.com-17475-1403467891.1.jpg) I think you might be right. Found this weeping at the back of the engine this morning after wiping it clean last night. |
Mike Bellis |
Pretty easy fix but you have to pull the tranny.
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Is it oil or gear lube? Looks kinda green, unless you're running brad penn oil.
swooshdave |
I think it's the poor lighting. No idea what oil is in it.
Cary came over and took at look at it. The consensus is the main seal. Going to drop the motor at some point and do the seal and the pushrods. |
dangrouche |
dangrouche ![]() ![]() ![]() Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None ![]() |
i had the same issue years ago; here is a pic of my leak. It was the rear main seal. touch and smell it; tranny oil has a higher pungent smell than motor oil
Attached image(s) ![]() |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Not (just) the tranny. That engine definitely has leaks. In your first pic it looks like an oil drop about to fall from the boss at the rear of the case on the bottom.
swooshdave |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,104 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Start the PBblaster routine on your exhaust stud nuts. If the rest are like the one pictured it's going to be a long process. The one we can see is as rusted up as they come. (IMG:style_emoticons/default/icon8.gif) (IMG:style_emoticons/default/barf.gif)
swooshdave |
I'll hit them up but I do you need to pull the exhaust off to do either of the seals mentioned?
jacksun |
Member ![]() ![]() Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest ![]() |
people have posted that they have changed the tube seals without removing the
engine or exhausts. it is tight for a couple of the tubes. I have chosen to remove the engine to do all the cleaning and seal replacements. also do the hell hole. the advice given within the instructions found at pelican parts regarding removing the engine that I found very helpful, was to have two floor jacks. as you can see I used the floor jacks to lift my engine and place four stands for extra safety.. of course each to their own/resources. I am in the process of cleaning my engine/trans.. it would seem that the tube seals and valve cover gaskets had not been replaced in many miles. ![]() ![]() |
PlantMan |
Member ![]() ![]() Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California ![]() |
I'll hit them up but I do you need to pull the exhaust off to do either of the seals mentioned? I just changed out my pushrod seals without removing the exhaust but did remove the heater boxes and misc steel under the car from the exchangers forward. Engine was in the car BTW. I can see by your other post that you do not have the heater boxes so you will save yourself some time. Give yourself a day (8 hours) if you are going to change the pushrod seals, especially if it is your first time. You will want to get in there and clean-up in and around the seals good. It is not difficult to do but you will spend a lot of time cleaning while pulling tubes, changing seals, etc. Do a search within this site for the process. I learned a lot about removing the rocker arms, retaining wire, piston positions, and making sure everything goes back together properly. However, if you plan on dropping the engine at some point...you probably could live with a few drops of oil and little smoke! (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 21st June 2024 - 12:03 AM |
