Weld thru primer, Where do I buy |
spunone |
Jan 19 2005, 09:59 AM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Making some metal patches for the rust bucket which need to be welded on .Where can I buy the weld thru primer to spray on both sides before welding since one side can't sprayed later.Thanks
Rusty |
Jan 19 2005, 10:07 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,952 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
3M makes a nice zinc weld through primer that you can buy at most auto body stores. I've bought it at local auto parts stores sometimes, too.
-Lawrence |
vortrex |
Jan 19 2005, 10:17 AM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
yeah I used this 3M and worked good. I got it at an autobody supply store.
spunone |
Jan 19 2005, 10:22 AM
Thanks Auto body supply it is (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
914GT |
Jan 19 2005, 10:25 AM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
If you can't find it anywhere else locally, FinishMaster will have it for sure. There are several in the LA area.
spunone |
Jan 19 2005, 10:28 AM
Better yet Thanks
airsix |
Jan 19 2005, 08:08 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
I use the 3M as well. Don't give up if the first shop you go to doesn't cary it. I went to at least 4 autobody/paint supply stores before I found "weld-through primer". The first shops didn't even know what I was talking about. The fourth shop had 4 different types. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Bet you can guess where I'm going next time.
-Ben M. |
DJsRepS |
Jan 20 2005, 07:03 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
I read this thread too late had no primer before the repair. I did grind and clean and prime with self etching primer from auto paint supplyer. Never heard of weldthrough primer learn sumptin new every day on this club. I did use Galv metal I know it burns off easy near the welded area but the middle galv is intact.
Lo-Fi Version | Time is now: 21st September 2024 - 07:07 PM |
