starts but won't continue to run |
jmargush |
Jun 26 2014, 11:54 AM
Member Group: Members Posts: 463 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
2056 running L jet
Drive the car for about 30 min parked it for about 15 then started back. It started to cut out and then just died. It will start and run for a few seconds but then dies. There is fuel and spark. Any ideas? Don't see any pinched lines any where. Ambient temp is 77 degrees |
Kirmizi |
Jun 26 2014, 12:05 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Fuel filter? (IMG:style_emoticons/default/confused24.gif)
Cap'n Krusty |
Jun 26 2014, 12:15 PM
I'd look for a vacuum leak first thing.
The Cap'n |
jmargush |
Jun 28 2014, 04:38 AM
Fuel filter was changed recently
I'll recheck vacuum lines but haven't seen anything of yet Does it possibly sound like plugged screen on pick up tube in tank? |
Porschef |
Jun 28 2014, 05:25 AM
How you doin' Group: Members Posts: 2,170 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Cutting out sounds like fuel starvation. Your sock idea is logical, mimics the effect of a clogged fuel filter. Pull your new filter (easier than the tank (IMG:style_emoticons/default/chair.gif)) and check for ANY signs of contamination which may indicate crud. IIRC, you can get a flashlight and see the sock either thru the sender hole or filler once removed.
injunmort |
Jun 28 2014, 07:40 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
if vacuum leaks and fuel filter check, I would suspect the coil is failing.
they work when cold then expand as they get hotter and the winding separate. it will still throw a spark but not consistently |
bdstone914 |
Jun 28 2014, 07:44 AM
bdstone914 Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Check for fuel pressure. If it is getting starved the pressure will drop quickly after startup. You can rent for free a fuel pressure tester at an OReilly or Autozone store. Test at the port on the fuel rail. Be sure to wash off any spilled fuel after removing the tester so it does not start a fire.
Mblizzard |
Jun 28 2014, 01:33 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Also check to be sure the fuel pump continues to run and it is not cutting out for any reason. If it is fuel starvation due to debris in the tank and line, I would replace all of the fuel lines. Tangerine Racing has the stainless Steel tunnel lines and a kit for the other fuel hoses. Get the fuel sock also.
I would install an in line fuel pressure gauge. It helps a bunch when you have issues. Mine would not start after doing some work. Checked the gauge. Pressure = 0. Go put the wire you knocked of the fuel pump back on and it's fixed. We'll worth it. |
Bartlett 914 |
Jun 28 2014, 01:46 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
It was running before the filter change? I would look for a kinked line where you changed the filter
jmargush |
Jun 28 2014, 06:52 PM
It ran for quite some time after the filter change I even pulled the pump out from under the tank when it died to make sure that wasn't an issue.
I even changed coil while on the side of the road with no difference. Haven't had time to get back out and see if it magically starts and runs |
jmargush |
Jun 29 2014, 04:49 PM
Just tried to start it and it is still doing the same thing.
put a meter on the pump contacts and no voltage when I move the flapper in the airbox (key on). There is voltage when the engine is cranking but as soon as it starts and I let off the starter no voltage. Does this point to the relay? Refresh my memory is the pump relay on the relay board in the engine compartment? Or should I check something else? |
motorvated |
Jun 29 2014, 05:07 PM
Member Group: Members Posts: 281 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
Just tried to start it and it is still doing the same thing. put a meter on the pump contacts and no voltage when I move the flapper in the airbox (key on). There is voltage when the engine is cranking but as soon as it starts and I let off the starter no voltage. Does this point to the relay? Refresh my memory is the pump relay on the relay board in the engine compartment? Or should I check something else? Fuel pump relay is hanging off the battery tray. I'd check for loose or unconnected wires there for sure. |
Mblizzard |
Jun 29 2014, 07:27 PM
timothy_nd28 |
Jun 29 2014, 07:33 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Ljet is a different animal, the dual relay near the battery tray runs the fuel pump.
timothy_nd28 |
Jun 29 2014, 07:56 PM
Just tried to start it and it is still doing the same thing. put a meter on the pump contacts and no voltage when I move the flapper in the airbox (key on). There is voltage when the engine is cranking but as soon as it starts and I let off the starter no voltage. Does this point to the relay? Refresh my memory is the pump relay on the relay board in the engine compartment? Or should I check something else? I think you are on the right track. If you manually deflected the AFM flap, and no fuel pump action with the key on, could be one of three things. Start by testing the continuity of pins 36 and 39 at the AFMs connector. You should see 0 ohms with the flap deflected and infinite ohms when the AFMs flap is at rest. Start with this test, and report back. |
sixnotfour |
Jun 29 2014, 09:24 PM
914 Wizard Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
flapper stuck closed , push it open and listen for fuel pump...
the flapper door gets sticky or warped. |
jmargush |
Jun 30 2014, 05:39 AM
looks like it is the relay
I tapped on it a few times and then moved the flap and the pump ran. thanks for your help guys |
Lo-Fi Version | Time is now: 25th June 2024 - 12:41 AM |
