Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
Well I had been very happy about the water tightness of my car after replacing so many of the seals. But tonight it was hammering rain and I felt a drip on my leg. It was coming from somewhere around the front trunk latch pull. (IMG:style_emoticons/default/WTF.gif)
The only thing I could think of is the seal around the windshield. Any thoughts on what to check? I think I am pulling off the windshield chrome. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Well I had been very happy about the water tightness of my car after replacing so many of the seals. But tonight it was hammering rain and I felt a drip on my leg. It was coming from somewhere around the front trunk latch pull. (IMG:style_emoticons/default/WTF.gif) The only thing I could think of is the seal around the windshield. Any thoughts on what to check? I think I am pulling off the windshield chrome. I doubt that it would be from the windshield. Check the front trunk for any water. See if the hood seal is sealing all the way around. Bruce |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,694 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Do you have an antenna on the drivers side? Could be leaking from the hole in the fender where the antenna cable goes inside the trunk.
Also check where the two evap hoses enter the trunk. All of these enter from the inner fender well right above where the trunk latch mechanism is located. (IMG:style_emoticons/default/idea.gif) |
Mblizzard |
Well I had been very happy about the water tightness of my car after replacing so many of the seals. But tonight it was hammering rain and I felt a drip on my leg. It was coming from somewhere around the front trunk latch pull. (IMG:style_emoticons/default/WTF.gif) The only thing I could think of is the seal around the windshield. Any thoughts on what to check? I think I am pulling off the windshield chrome. I doubt that it would be from the windshield. Check the front trunk for any water. See if the hood seal is sealing all the way around. Bruce Just installed new front trunk seal. No water in trunk. |
Mblizzard |
Do you have an antenna on the drivers side? Could be leaking from the hole in the fender where the antenna cable goes inside the trunk. Also check where the two evap hoses enter the trunk. All of these enter from the inner fender well right above where the trunk latch mechanism is located. (IMG:style_emoticons/default/idea.gif) Have antenna. Did not check that but that would seem a long way for water to travel. But I will see what I find. |
zambezi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States ![]() |
The water can splash up in the wheel well and hit the underside of the antennae and the antennae wire and then travel on the wire and through the grommet if it is not sealed well. It will then drip onto your leg inside the car.
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
I'd squirt a hose only on the trunk seal, not the windshield. . flood it exactly as it was when it was pouring. . Open hood and look above drives pedal area where you felt the drip. . if you don't visually see anything, wipe it with a Kleenex. . which will pick up any trace water amount.
Are your drains on the air vent opening connected and not plugged up? If it's leaking at the windshield glass, it would have to overcome the height of the inside sealing lip. . or have found a rust hole. . |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,597 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Did you take your prostrate medication today?
Mblizzard |
Wow I must be posing my mind. I thought I posted an update, but that was a couple of beers ago!. I will try again.
The winner is a leaking windshield. ![]() Found that the windshield was not attached to the adhesive in the corner where I saw the leak. A little pushing and probing showed that the chrome trim was all that was really holding the windshield in. Except for that one spot that caused the windshield to crack all the way down. But it provides great access for changing the dash vinyl! ![]() |
Lo-Fi Version | Time is now: 20th June 2024 - 06:20 AM |
