zephyrblau |
Newbie ![]() Group: Members Posts: 2 Joined: 30-June 14 From: castro valley, ca. Member No.: 17,567 Region Association: None ![]() |
first post... please be gentle (IMG:style_emoticons/default/shades.gif)
it's been a long time since the old Road Glue days, but be that as it may I have a question that may seem counter intuitive. here goes; (digest version) can I put '73 - '76 type 914 struts in a 911 ? ...and what would I need to add or change ? the desired result is simply to be able to move the car around the shop. I can see that the tie rod mountings are straight vs. 911 type. if it makes a difference the struts are Bilstein. any help appreciated. TIA jerry |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
I did just that when I was moving an old 911 tub. Other than perhaps different pinch bolts (or wedge bolts) at the bottom ball joint, they'll bolt right up, and should be fine for pushing the car around.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
What year 911?
Will not work on a short wheel base car. |
zephyrblau |
guys... thanks for the replies. the SWB consideration is well taken. I'm starting to think the interested party isn't simply looking for "...something cheap just to move the car around the shop", but is just looking for "...something cheap".
Lo-Fi Version | Time is now: 25th June 2024 - 09:13 PM |
