HalfMoon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region ![]() |
Anyone know which spade powers what?
For instance, 53=powers/switches/grounds? High, low, parked? 53a=powers/switches/grounds? High, low, parked? 53b=powers/switches/grounds? High, low, parked? 31b=powers/switches/grounds? High, low, parked? And I've read that the poles are powered/switched/grounded differently between late and early wiper motors.... See picture. D ![]() |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Red/Black - Hot from fuse
Green/White - Park Black/Blue - Slow Black/Violet - Fast Brown - Ground |
HalfMoon |
Red/Black - Hot from fuse Green/White - Park Black/Blue - Slow Black/Violet - Fast Brown - Ground Thanks for that! I'm horribly color blind btw. Soooo, Red/Black - Hot from fuse=53a Green/White - Park=31b Black/Blue - Slow= Black/Violet - Fast= Brown - Ground=where I have a question mark in an arrow In theory I should be able to run a hotwire from the pins that operate the high/low for a test, right? As an aside the pins when tested to ground read 53a=1.900 ohm 53b=.500 ohm 31b=1.100 ohm 53= .340 ohm And I further assume the unit would have to be grounded for a hotwire test (if the test were being done for an un-installed motor)? |
Mike Bellis |
Red/Black - Hot from fuse Green/White - Park Black/Blue - Slow Black/Violet - Fast Brown - Ground Thanks for that! I'm horribly color blind btw. Soooo, Red/Black - Hot from fuse=53a Green/White - Park=31b Black/Blue - Slow= 53 Black/Violet - Fast= 53b Brown - Ground=where I have a question mark in an arrow In theory I should be able to run a hotwire from the pins that operate the high/low for a test, right? As an aside the pins when tested to ground read 53a=1.900 ohm 53b=.500 ohm 31b=1.100 ohm 53= .340 ohm And I further assume the unit would have to be grounded for a hotwire test (if the test were being done for an un-installed motor)? I fixed it |
Mike Bellis |
HalfMoon |
Red/Black - Hot from fuse Green/White - Park Black/Blue - Slow Black/Violet - Fast Brown - Ground Thanks for that! I'm horribly color blind btw. Soooo, Red/Black - Hot from fuse=53a Green/White - Park=31b Black/Blue - Slow= 53 Black/Violet - Fast= 53b Brown - Ground=where I have a question mark in an arrow In theory I should be able to run a hotwire from the pins that operate the high/low for a test, right? As an aside the pins when tested to ground read 53a=1.900 ohm 53b=.500 ohm 31b=1.100 ohm 53= .340 ohm And I further assume the unit would have to be grounded for a hotwire test (if the test were being done for an un-installed motor)? I fixed it Thanks for that! Using the data I tested my spare both high and low work. A lil concerned about 53a only pulling 1.9 ohm on the spare :-( But it ought to work. My current wiper motor is zero ohm at 53a so that ain't gonna flush. Thanks again :-) |
Lo-Fi Version | Time is now: 26th June 2024 - 06:39 AM |
