buck toenges |
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None ![]() ![]() |
Is there a fuel pressure regulator bracket for a 1970 1.7 engine? I assume if there is one would it be located on the engine tin or engine block? Or does the fuel regulator just lay on the engine tin?
Thanks, Buck |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Is there a fuel pressure regulator bracket for a 1970 1.7 engine? I assume if there is one would it be located on the engine tin or engine block? Or does the fuel regulator just lay on the engine tin? Thanks, Buck It is supposed to be attached to a bracket that is welded to the left engine tin at the rear. If it is missing, you can get one and bolt it on. |
eyesright |
Member ![]() ![]() Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region ![]() |
There is one on my '76 but it was broken when I got it. The regulator seems to be well supported by the FI hose on both sides, doesn't bang against the sheet metal, so I have left well enough alone. I check it now and then.
I have wondered if it broke due to vibration/metal fatigue but I think that takes a lot of very high frequencies such as you find on jet engines and that bracket is pretty stout. No idea. |
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,193 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Is there a fuel pressure regulator bracket for a 1970 1.7 engine? I assume if there is one would it be located on the engine tin or engine block? Or does the fuel regulator just lay on the engine tin? Thanks, Buck It is an L shaped piece of sheet metal with a hole in it for the regulator to attach to. If it is broken off and gone you can attach one to the engine tine with sheet metal screws or rivets if you don't want to weld it. I had to fabricate and weld mine in. Long gone. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:27 AM |
