Jon H. |
Member ![]() ![]() Group: Members Posts: 237 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada ![]() |
Is there a common ground for the instrument cluster and if so, where approx is it located? I have no signal lights and no power to the instruments. The genny light was also on. The car was running fine then I let it sit for about two weeks and this started. I assume its a ground? Could a loose alternator belt cause this? My belt is a liitle loose, I will sort that out tonight regardless.
Thanks' Jon |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
If you lose all power to the instrument cluster, then ALT light will turn on because it will have +12V on the Alt side and 0V on the instrument side.
Jon H. |
Thanks, that'll give me a start with fixing this issue.
Jon |
Lo-Fi Version | Time is now: 26th June 2024 - 02:07 AM |
