Newbie help, Small projects |
walter j |
Aug 13 2014, 01:30 PM
Newbie Group: Members Posts: 8 Joined: 15-November 11 From: New York Member No.: 13,790 Region Association: None |
Hi there all,
I am trying to get up the gumption to get started on some small projects on my car - -1970 914 -6. I working on getting my windshield washer to work and want to replace the tubing and valves (?) and the hardware on the body that the liquid sprays out of. The pump does work, I can hear it engage when I depress the staulk on the column. Is there a reccomendation as to where to get these parts? I tried to locate them on Automobile Atlanta's site, but could not. Also, I wanted to install a bracket for my fire extinguisher and I was told that Brey Krause was a good source for that. Any thoughts? Excuse the simplicity of the requests, but I am just getting started and want to start small. Thanks |
Elliot Cannon |
Aug 13 2014, 01:40 PM
walter j |
Aug 14 2014, 03:06 PM
Thanks for your help. |
914Sixer |
Aug 14 2014, 07:11 PM
914 Guru Group: Members Posts: 8,915 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Ask away and you will get all the help you can use.
Spoke |
Aug 14 2014, 08:43 PM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
You'll get better help if you show some pics of your car. Plus you won't get anyone hitting you with a: (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 11:24 PM |
