rosenfe |
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None ![]() |
my 73,one bleeder valve broken off,it still holds pressure,but i would like to eventually rebuid the caliper,wondering how to get the broken bleeder out ?
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Drill and Easy-Out
Small drill so you don't screw up the threads. Easy-Out to match the drill size. Drill only deep enough for screw extractor to get a bite. |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,825 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
Send it to Eric. Much simpler method and the results are guaranteed
rosenfe |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
Send it to Eric. Much simpler method and the results are guaranteed i know i could send it to eric,its an extra 80 dollars,plus i want to rebuild my own caliper.his video is excellent.ill try easy out and drill be careful, I did this a few months ago, here is what eric told me-you can leave it alone(mine were just rebuilt from PMB), it should still bleed out fine, and hold pressure fine. I messed mine up the easy out did not work and in the end I am not sure he was even able to save the caliper. cores are only worth 10-20$ so its not worth spending a lot on it if you mess it up. but if you are rebuilding it you may be able to back it out if you are really careful. good luck Phil |
Lo-Fi Version | Time is now: 29th June 2024 - 03:40 AM |
