> Will lowering my front change the alignment ?, Torsion Bar Adjustment
v82go
post Jan 25 2005, 05:26 PM
Resident Contrarian
Will lowering my front "via torsion bar adjustment" change my alignment ? Help---- me fronts too high !
post Jan 25 2005, 05:32 PM
Resident German
QUOTE (v82go @ Jan 25 2005, 03:26 PM)
ayupp ...
you'll need to get it re-aligned ...
(IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy
Kerrys914
post Jan 25 2005, 05:34 PM
Dear, the parts I just sold paid for that part ;)
(IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Yep..
Guys please correct me if I am wrong.
Camber; you will have more (-) camber or Top of the tire tilted in more.
[B]Toe-in/out; Should stay the same
Caster;[/B] I think the number will change but the change will be the same on both sides and that is more imprtant then the number.
This is all based on the fact your alignment was correct to start with (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
IronHillRestorations
post Jan 25 2005, 05:38 PM
I. I. R. C.
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
Step one of setting alignment is setting the ride height. Make sure you've got at least a minimum of 1/4" rake, the front has to be lower than the rear. You can measure the difference at the front and back edge of the rocker panels.
Be careful going too low, you'll run out of suspension travel and the car will ride very rough, probably handle better, but ride like a buckboard. Also if you've got low profile tires on 15" wheels, and you lower the car alot, you may start scraping.
post Jan 25 2005, 05:42 PM
Resident German
QUOTE (9146986 @ Jan 25 2005, 03:38 PM)
you can also rip off your fiberglass flares if the car is too low!
all you need to do is to hit a bump while cornering and off they come ...
not gud!
(IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Andy
Trekkor
post Jan 25 2005, 05:51 PM
I do things...
Here's a couple a low ones.
First thing I did on both my cars was slam them way down.
Gravel pusher... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
They do handle a ton better and I think they look better , too.
I have adjustable rear spring perches so it isn't raked as steep.
After the bump steer kit, turbo tie rods and alignment were done. Wowie wow wow, wow! Look out! (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif)
If you don't get the alignment or other items you won't really hurt anything*. Tires may wear funny ( rotate them ).
The extras I mention help you to realize the potential handling this car can offer.
KT
* I ran most of the a/x season and street driving with it lowered only. Only stepped up for the last few events.
v82go
post Jan 26 2005, 08:48 AM
Resident Contrarian
THANKS for the HELP!
- Lo-Fi Version Time is now: 4th January 2025 - 11:08 PM
